Suspension & Brakes Theory, alignment, spring rates....
ebay extended top hats on koni/springs?
Old Aug 16, 2010 | 01:57 PM
emooheo's Avatar
Default ebay extended top hats on koni/springs?
Do ebay extended top hats fit koni yellows?
Do the extended top hats work with lowering springs? i have only seen them on coilovers. I have stechs.
Old Aug 16, 2010 | 05:42 PM
98civdx's Avatar
Master Detailer
Default Re: ebay extended top hats on koni/springs?
You can use extended top hats on springs if you would like, lots of people chose to do so when lowered over 2 inches.
Wether or not ebay ones will fit I dont know.
i saw on weaksauce koni is 12mm and stock is 10mm.
Old Sep 1, 2010 | 01:31 AM
colgateam's Avatar
I'd like to know if those ebay ones would fit koni yellows too.
Bump
Old Sep 1, 2010 | 04:17 PM
GSRCRXsi's Avatar
they should fit fine if you swap out the sleeves to the 12mm sleeves that konis need (the konis come with them)
Old Sep 2, 2010 | 01:27 AM
kristo's Avatar
Loved
The question is not whether those will fit, but whether they will hold
dragonfly2k3
Jul 18, 2008 12:31 PM
Psychochik
Honda Civic (2001 - 2005)
19
Mar 15, 2008 11:02 PM
Jhonny Ricer
Suspension & Brakes
Mar 29, 2007 03:27 AM
iLLA
Dec 20, 2005 01:30 PM
Boostless97Lude
Aug 6, 2003 01:25 PM
