bad starter???? how to know
Old Aug 14, 2010 | 11:37 AM
brian8702's Avatar
Default bad starter???? how to know
ok how do you know if your starter is good or bad?
i did a h22 swap but i think my problem is with the starter.
i just replaced the ground wire that goes from the battery to the block.
i tried taking a hot wire to the starter and it didnt do anything.
also i think theres a ground missing on the bracket on the transmission.
im not sure. theres two holes in the backet and the one hole is where the ground wire from the battery goes.
any suggestions???
Old Aug 14, 2010 | 02:32 PM
accord99power's Avatar
Default Re: bad starter???? how to know
hammer on the starter with a big hammer, don't go crazy on it but give it a few good wacks. or wack on it while havin a friend turn the key over. or if a manual tranny, push the car then turn the key and pull the clutch out while rolling. if any these work bad starter or take it out and test at local auto parts store.
hondachris1994
Aug 15, 2019 03:07 PM
hondachris1994
12
Nov 9, 2017 05:15 PM
GoBrowns
Oct 3, 2013 02:56 AM
HT Chaplain
Jul 28, 2009 05:33 PM
GoodEyeSniper
17
Sep 8, 2006 11:31 PM
