Idel adjust
Old Sep 16, 2002 | 10:58 PM
NZcrx88's Avatar
Default Idel adjust
Hi Guys!
I try to adjust the idel but when I disconnect the connector from the
EACV valve, then start the engine, the idel stays same at 1000 rpm.
Does it mean my EACV is bad? When I check the ECU there is no code.
Do I need to change a new EACV or it could be repaired?
Thank you for any ideas!
Old Sep 18, 2002 | 07:28 AM
TimoneX's Avatar
New User
Default Re: Idel adjust (NZcrx88)
It's supposed to drop to 450ish isn't it? Hmmm...and you're not getting any codes?
Old Oct 23, 2002 | 05:17 PM
GZERO's Avatar
Default Re: Idel adjust (TimoneX)
what are you supposed to do after it dropped? i want to raise my idle but i can't. i have a 95 accord LX
Old Oct 23, 2002 | 05:38 PM
GZERO's Avatar
Default Re: Idel adjust (GZERO)
please guys?
i need to disconect the IACV, and is supposed to be on the back of the IM, but which one? the one that looks like a lil motor? and what do you need to move the idle screw? a screwdriver?
need help ASAP
MrTodd's Avatar
Wait, so that's all you did? Just disconnected the EACV? (NZcrx88)
Didn't you try adjusting the idle screw at all?
The purpose of the EACV is for the ECU to adjust the idle speed automatically, once it's disconnected the idle speed will stay at a constant speed - this is the base idle speed. Adjust your base idle speed to about 500 rpms, by tightening the big idle adjusting screw...
[Modified by MrTodd, 7:40 PM 10/23/2002]
Old Oct 23, 2002 | 05:41 PM
GZERO's Avatar
Default Re: Idel adjust (MrTodd)
ok, i know that, but the idle screw is the one that faces the valve cover, right? what type of screw is this? do i have to jump the service connector?
Old Oct 23, 2002 | 05:42 PM
MrTodd's Avatar
please guys?
need help ASAP
You said you drive an accord? The IACV should have two coolant lines that connect at the bottom of it, and a wiring harness that clips in as well. It kinda does look like a little electric motor....
Just unplug the wiring harness from the IACV, then adjust the base idle speed by tightening/loosening the idle adjust screw (big flat head screw, usually located on the throttle body)
enano
Oct 11, 2006 08:35 AM
Spade
Aug 14, 2005 07:28 PM
flood
Mar 30, 2005 08:46 AM
carblegal
Dec 25, 2004 09:51 PM
phill
Sep 9, 2004 08:01 AM
