Some recent CNC Work
Old Aug 11, 2010 | 10:47 AM
BMCRace's Avatar
Default Some recent CNC Work
Old Aug 11, 2010 | 11:00 AM
J35monster's Avatar
Default Re: Some recent CNC Work
<---Needs to change his underwear now
Wow BMC doin it up big time!!! That looks insane.
Old Aug 11, 2010 | 12:16 PM
SL0WEGG's Avatar
Thats just ridiculous lol
Old Aug 11, 2010 | 12:27 PM
BMCRace's Avatar
thanks guys.
This was our first to machine and for some reason it decided to leave some little machine marks at the top where the logo is. That will be worked out before the next one is finished.
Should be finishing this one up within a couple of weeks, then it all gets anodized and out to its rightful owner...
I am expecting it to take around 500 amps to fully weld that together. Thank god we have the Dynasty 700!
Old Aug 11, 2010 | 12:37 PM
russianvr4's Avatar
OG Fabricator
500 amps!!!!!!!!!!!!!!
Old Aug 11, 2010 | 01:07 PM
BMCRace's Avatar
well that is technically pulsed at 500pulses per second.
Running hot like that and pulsing super fast keeps alot better arc control and keeps the tungsten form deforming so bad. High frequency makes a big difference too but constant heat will destroy it really quick if your not careful.
Old Aug 11, 2010 | 01:14 PM
russianvr4's Avatar
OG Fabricator
what freq and tungsten do you use when welding thick alum like this?
i've been using orange at 120hz on my dyn350 and the tungsten deforms pretty badly
Old Aug 11, 2010 | 01:17 PM
BMCRace's Avatar
I always run 400hz on all my aluminum welds
Since day one when I got it out of the box it was 400hz boom! lol
It keeps the welds nice and small and you can run very hot without tearing up the tungsten. I use 1/8" orange at 350 amps and the tip just barely ***** over. With 3/32nd it will ball to big and actually drip and ruin a weld but with 1/8th things are smooth as butter.
Old Aug 11, 2010 | 01:18 PM
russianvr4's Avatar
OG Fabricator
hmm, i'll have to try that out. thanks!
Old Aug 11, 2010 | 01:21 PM
BMCRace's Avatar
no problem.
Old Aug 11, 2010 | 03:20 PM
longevityrep's Avatar
that's a great design....i like the way its chromed out and the letters are neat too.
Old Aug 11, 2010 | 04:09 PM
russianvr4's Avatar
OG Fabricator
where do you see chrome?
Old Aug 11, 2010 | 05:24 PM
frostyrb's Avatar
i have been welding the same way with my dynasty 350. balance @ 75 hz @ 400 & between 500 to 1000 pulses per second depending on what the material is. i asked if anyone else was doing this in someone elses post, but i got no responses. the lowest i ever go on the hz is like 250, & i cannot stand to use a transformer machine anymore!
Old Aug 11, 2010 | 05:28 PM
russianvr4's Avatar
OG Fabricator
the noise at 400hz is pretty annoying LOL. my now deceased husky would run away when i'd weld aluminum at 400.
Old Aug 11, 2010 | 05:33 PM
E-Rok's Avatar
EPIC TUNING
damn thats sick
Old Aug 11, 2010 | 05:41 PM
BMCRace's Avatar
lol yep it sounds like an alarm clock that wont shut up! at least you won't have to worry about being tired on those early mornings, that **** will wake the dead haha
Old Aug 11, 2010 | 06:16 PM
E-Rok's Avatar
EPIC TUNING
the most I used was 250hz I think thats all dynasty350 will do
Old Aug 11, 2010 | 06:55 PM
frostyrb's Avatar
no the dynasty 350 will do 400hz. i think the dynasty 200 only does 250 or it might go up to 300. i can't remember off hand.
Old Aug 11, 2010 | 07:44 PM
E-Rok's Avatar
EPIC TUNING
well we had two diff ones a reg 350 and a DX. almost positive the regular ones went to 250 and the DX went to 300. These machines are like 4 years old now.
Old Aug 11, 2010 | 07:45 PM
russianvr4's Avatar
OG Fabricator
mine sure does 400hz!
Old Aug 12, 2010 | 06:31 PM
frostyrb's Avatar
hey e-rok do you have a dynasty 350 or a 300. i think the 300 was first then miller went to the dynasty 350.
Old Aug 12, 2010 | 06:35 PM
E-Rok's Avatar
EPIC TUNING
I have a Lincoln Precision TIG 275
We had Dynastys in school.
Old Aug 12, 2010 | 07:05 PM
all_motor_mike's Avatar
damn my invertec only goes to 150hz =(
mike
Old Aug 12, 2010 | 07:17 PM
E-Rok's Avatar
EPIC TUNING
I think if I get the optional control panel for my PT275 it goes to 20Hz LOL. ****ing Transformers......
Old Aug 12, 2010 | 09:10 PM
9bells's Avatar
OG Fabricator
20 hz, you're funny Rok. 60 out of the wall.
Nice work, very unique.
As for the welding, 500amps seems like overkill, but it should look nice if you move fast enough. I think 300 amps would do fine. I really use the variable polarity amplitude adjustment if I'm over 100amps. You rarely need more than 100 amps of cleaning(especially billet cnc stuff) and you can really save the tungsten. I did a job for the polytechnic, and I did it at 320 amps EN, 120 amps EP, 90% balance, and 400hz. It was 3/4" thick, and 2 ft long. Welded like butter. Anyway, not trying to tell anybody how to weld, just throwing my 2 cents in. Nobody talked much about that, which I think is the best feature once you take the leap past the 200.
I really haven't used the 400hz much except for tacking without filler, or getting into tight spots, as I really like 250hz for my aluminum exhaust. Might have to tinker again. The dynasty 350/700 almost have too many variables...almost!
