Brembo conversion from ITR
Old Aug 11, 2010 | 04:47 AM
firstorlast17's Avatar
Default Brembo conversion from ITR
hey everyone, i have a premium 04 rsx,,, i picked up the brembo brake setup from the type r.. i was told it was a simple bolt on but i learned that the aluminum lower control arms that the type r comes with doesnt match up with where my sway bar would bolt on... i had to do some research to find out that i needed the sway bar from a type r... after finding them the last thing i knew i needed to do the conversion was the type r axles (36mm). im almost sure i have everything necessary to do the swap. ss brake lines, motul 600 brake fluid etc.. does anyone know if i will be needing anything else for the conversion. i have a track day coming up on the 21st and would love to have the brakes put on by then.
thanks!
any info is much appreciated
Old Aug 11, 2010 | 01:17 PM
hawaiiancb74's Avatar
Default Re: Brembo conversion from ITR
i know plenty of track dc5s that dont even run a front sway.. but anywho it sounds like yer on top of it and ready to go.
Old Aug 11, 2010 | 06:35 PM
DaveSi677's Avatar
seems you got everything... just make sure you break in the brakes properly before the track day!
Old Aug 11, 2010 | 07:19 PM
thanks guys
Old Aug 22, 2010 | 07:24 PM
installed the brembos with the ITR hub with the aluminum lower control arm,,,, used the type s axle because they're 36mm.. i thought this was right but i have been noticing huge vibrations coming from the front end.i think i should have got the ITR axels, because the ITR hubs are wider, the type s axels look like its being pulled out and is not in the right position going into the differential.... can anyone confirm that i need the ITR axels, or is it something else?
thanks alot
Old Aug 25, 2010 | 09:44 PM
97 TYPE-R 312's Avatar
You need the TYPE-R axles or the S axles will eventually pop out. I did this swap on my EP3 a couple years ago. I actually still have the DC5R Brembo swap I still need to sell.
Old Aug 25, 2010 | 10:03 PM
sorry i didnt pop in here earlier.. but yeah need r axles.
Old Sep 8, 2010 | 07:46 PM
thanks alot, im going to order from driveshaft shop the vibration is getting very annoying... but thanks a lot for clearing it up its been a pain in the a**
Old Sep 8, 2010 | 10:10 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
if I get Brembos I wouldn't do the type-R LCAs and sway bar and axles and etc.. to much work
If I bought ITR Brembos I would just buy the S2K rotors and call it a day. A simple bracket makes it possible for the brembos to fit and the s2k rotors are the right size
Old Sep 9, 2010 | 06:42 AM
WhiteOnRice's Avatar
PM me price. :D
Old Sep 15, 2010 | 07:16 AM
supercivicstack's Avatar
I have the entire kit, with a type S axle. Stock ep3 axles work too.
I am missing a brake retainer from one of the brembo calipers. I have no idea where to get this item, ive tried nissan, dodge, mitsubishi, and called brembo. Had no idea what i was getting at. Someone please help my find the brake retainer.
the whole point of this kit is for a wider stance the brembos are just a bonus... so im told.
Old Sep 15, 2010 | 07:19 AM
http://www.ephatch.com/forum/showthr...mbo-swap/page4
los02
Mid-Atlantic (Sales)
Aug 12, 2009 07:24 AM
dc5RickK20
Jun 8, 2007 05:32 PM
Irishweird00
Dec 29, 2005 10:02 AM
Convoy
19
Jul 19, 2004 10:47 PM
Mr.Civic
Jun 19, 2004 09:03 PM
