need help going crazy lower hose cold,fan dont come on
i've been going crazy trying to figure this out and iam right where i started. first i noticed my fan not comeing and my lower hose is cold. and top is hot, so whn i was changeing it i took off the top hose and it was broken the pice whr the hose goes onto.so there must be some pices in there somewhere i tried to flush the system out, then i changed the thermostat and fresh coolant.same problem. what ever i do its the same and the temp is way under half. the fan works i put power to it and it came on. i also changed the temp sensor. then i thought it was the water pump but it doesent leak or make noise so i dont know what to do if u have any ideas please HELP by the way its a d16y8 sohc vtec
normally a hot upper hose and cold lower hose points to the thermostat. but sicne you changed it i would say you need to bleed your cooling system to get out any air. air in the system can cause the thermodtat not to open and fan not come on.
to bleed the system run the engine with the radiator cap off, turn heat on. continually top of the radiator until both hoses are getting hot and the fan cycles on. if for any reason the car starts overheating before the fan comes on then look at other issues like possibly faulty thermostat or bad fan switch
thanks man that helped out it turned out to have air in the system and a bad fan switch but also found out a clogged hose from the manifold to the fan switch houseing, i dont know wht the hell it was inside but it was full of it
I wouldn't do that method ^.
There is a bleeder valve on the top of the coolant hose on the top. run the car and open the valve. This will release any air in the system.
I had a very similar issue as you and just bled the system, and I have had no issues so far.
dbailey
11
Jan 30, 2020 04:27 AM
xxitoonzxx
Feb 17, 2013 07:41 PM
Wrona
Dec 6, 2011 10:22 AM
Veleno
15
Mar 14, 2005 09:03 PM
