Honda S2000 Honda S2000
AP1, strange "Squeeking noise while decelerating"
Old Aug 10, 2010 | 08:42 PM
-=Zeqs=-'s Avatar
Icon2 AP1, strange "Squeeking noise while decelerating"
I have a 03 S2k with about 107,500 miles on it. The trans. and diff. fluids were changed when I bought my car at the beginning of the year, the car had about 95,000 miles on it at the time. The suspension is stock. The car has been driving fine up until the past week.
I started noticing last week with my music turned off, that as I'm slowing down, right around 30 mph and less, I'll start to hear a squeeking noise, kind like the bed springs in a college dorm when someone is having sex. As the car gets slower from braking, it becomes louder and louder. During the last few mph of slowing down, it sounds almost like really bad brake squeel. This doesn't seem to happen if I only drive the car for a short distance, like a mile or so.
At first I thought it was my front brakes, so I had those changed today. The pads still had some life in there, but it was getting close to time to change anyways. The rears looked like they still have a good amount of life on them, so we left it alone.
After I left the shop and started heading home, which is about 20 miles away, I started noticing it again. At this point, I am tripping out on where the sound is coming from, so I had a friend sit in my car with me while we went to dinner. She noticed the sound too, and discerned it as not from the passenger side of the car, but the driver's side. I then lowered the top, and it sounds more like it's coming from the rear.
Anyways, before I start ripping everything apart, does anyone have any suggestions as to what I should check, or perhaps have some idea what it could be?
Any insight is greatly appreciated. Sorry if this should be common knowledge, but I filtered through several pages posts and didn't see anything that fit the bill.
Old Aug 11, 2010 | 06:21 AM
JulieU's Avatar
Default Re: AP1, strange "Squeeking noise while decelerating"
LMFAO!! Have you retorqued your axle nuts? Sounds like the symptoms I had before I retorqued mine.
Old Aug 11, 2010 | 07:00 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
yeah and its like 125 ft-lbs of torque too... something crazy like that...
Old Aug 11, 2010 | 07:05 AM
JulieU's Avatar
More like 220 lb-ft.
See this link for more info... http://www.s2ki.com/forums/index.php?showtopic=782910.
Old Aug 11, 2010 | 07:30 AM
-=Zeqs=-'s Avatar
O_O I don't think I ever took them off to begin with :/
Old Aug 11, 2010 | 07:35 AM
-=Zeqs=-'s Avatar
YIKES!!! 181 lb-ft. O_O
Thanks for chiming in everyone.
Thank you for the link Julie, I'll look into it.
Old Aug 11, 2010 | 08:25 AM
S2KILLA's Avatar
haha i knew it was a high number... good job julie...
Old Aug 11, 2010 | 08:34 AM
S2KILLA's Avatar
Holy ****... just remembered my buddy has this same problem... lemme call him and tell him whats up...
Old Aug 11, 2010 | 10:15 AM
-=Zeqs=-'s Avatar
When did your buddy start noticing his symptoms?
Old Aug 11, 2010 | 07:22 PM
-=Zeqs=-'s Avatar
Axle nut was torqued still. Chek heat shields. Still making the noises
Old Aug 12, 2010 | 06:08 AM
JulieU's Avatar
Could be the wheel bearing then.
Old Aug 12, 2010 | 06:30 AM
S2KILLA's Avatar
or the infamous johnson rods...
Old Aug 12, 2010 | 07:08 PM
-=Zeqs=-'s Avatar
Johnson rods? O_o
Old Aug 12, 2010 | 07:13 PM
-=Zeqs=-'s Avatar
...Right...forgot, it's right up there on things to check after axle bearings and headlight fluids.
Old Aug 12, 2010 | 07:14 PM
-=Zeqs=-'s Avatar
I'll look into the wheel bearing, but if he wheel bearing were bad, wouldn't it make noises from the very get-go? It seems to only start making the noises after I've been driving for several miles.
Old Aug 13, 2010 | 07:59 AM
marshman's Avatar
gotta be the wheel bearing. i went through this very recently. in fact, i stripped the threads on the ball joints removing the knuckle and i still haven't gotten my car on the road since! but if it doesn't make noises all the time, you may be lucky enough to not have screwed up the hub like me.
if you do it yourself, it is highly reccomended to avoid using a pickle fork to separate the ball joints. and you can find the parts you need here: http://hardtopguy.com/store/home.php?cat=101
these are cheaper than any honda shop i've found by about $100 for the hub and bearing.
Old Aug 13, 2010 | 08:38 AM
marshman's Avatar
http://www.s2ki.com/forums/index.php?showtopic=223599
that's the wheel bearing/hub DIY in case you need it
Old Aug 13, 2010 | 11:47 AM
-=Zeqs=-'s Avatar
Thanks for the feedback, I'll look into that next.
Old Sep 11, 2010 | 07:02 PM
-=Zeqs=-'s Avatar
It was the rear, driver's side wheel bearing. Thank you Marshman and everyone for your help.
kcari
Suspension & Brakes
12
Mar 29, 2011 06:34 PM
skip.two
Suspension & Brakes
Jun 14, 2009 07:38 AM
NorcalHB94
Sep 29, 2004 01:31 PM
Briman2021
Jul 31, 2002 11:54 AM
