94 civic has no power at low rpm's!
Old Aug 10, 2010 | 09:47 AM
rondogg779's Avatar
Default 94 civic has no power at low rpm's!
i recently changed the head on my 94 civic ex and now it doesnt have any power at low rpm's.it doesnt seem like it is missing because it only does this while driving.once you start off it doesnt start to really pull until about 4,000 to 5,000 rpm.it alsoburning oil.the timing seems right and when you are in neutral and rev it up it is smooth.also the intake isnt as loud as it used to be it almost sounds stock.i really need some help with this so if anyone has an opinion please let me know.thanks
Old Aug 10, 2010 | 10:15 AM
d16y8turbo's Avatar
Default Re: 94 civic has no power at low rpm's!
How did you check the timing on it? Even if the cam timing is good the distributer timing can mess the response up.
Old Aug 10, 2010 | 11:26 AM
rogue420's Avatar
no power at low rpm's? This is typical honda behavior, what's the problem?
Old Aug 10, 2010 | 11:53 AM
d16y8turbo's Avatar
Hold On Not Done Accelterating
Old Aug 10, 2010 | 12:16 PM
Former User's Avatar
Any CEL codes? How old are the plugs, wires, cap, and rotor? If those are fine, do this:
Old Aug 11, 2010 | 06:17 AM
rondogg779's Avatar
we just marked the original timing when we pulled the head,and it is not throwing any cel's.when we put the new head on we had changed the timing up and it ran like ****,so we went back with the timing from the original head.it ran decent the first day or so but now it just has no power.if it was a sensor then it would throw a cel right?
Old Aug 11, 2010 | 06:21 AM
rondogg779's Avatar
could the timing also be the reason for the oil burning?it only does it at high rpm's but it does it pretty bad.
Old Aug 11, 2010 | 06:43 AM
You need to hook up a timing light to set the ignition timing to spec. Follow the procedure described in the diagram.
Oil burning is a separate issue. You may want to do cylinder compression and leak down tests.
Old Aug 13, 2010 | 08:00 AM
rondogg779's Avatar
it seems that i haver spun a rod bearing.now i am trying to find a cheap block.
Old Aug 13, 2010 | 12:09 PM
rondogg779's Avatar
i found a complete motor d15b7 for $100.would it be worth throwing that in?and would my starter,alternator,etc. match up with it???im just trying to for see some of the problems if any i might run into while doing this.i need to get it all dont tomorrow.
Old Aug 13, 2010 | 01:03 PM
d16y8turbo's Avatar
The transmissions are interchangeable for the d series engines, so that would mean the starter would work. I would bet it's a bolt-in affair. $100 is a good price for a running engine.
Old Aug 14, 2010 | 04:50 AM
rondogg779's Avatar
the guy says that it is running i would really like to bench test,but is there a way to do this with out bolting the tranny on it?also would my z6 work with it also?i would like to keep it v-tec seeing is how i just had my head done .
Old Aug 16, 2010 | 09:05 PM
USDM sI's Avatar
of cours eur hea dwill work but to be honest bro
be careful those b7s have WEAK *** rods ive gone through 3 B7 blocks alredy w my z6 head... all thrown rods havent found any of them haha
your best bet if your staying stock as far as internals is either a z6 or a6 blocks ive ran a z6 head w a b1 b2 b7 a1 a6 z6 and y8 and the best damn ones by far were the a6 and z6 the y8 did good to but i spun 3 bearings it had 13:1 cr probily why ha
HondaTechMan121
Jun 12, 2016 03:33 PM
biggishjay
Apr 29, 2007 09:18 AM
n0ten0ughrice
Nov 28, 2006 09:09 AM
keanevann2005
Jun 28, 2006 05:19 AM
95greensol
Mar 1, 2005 09:22 AM
