delsol b swap
Old Aug 10, 2010 | 08:54 AM
meric0786's Avatar
Default delsol b swap
ok got a 93 sol s puttin in a 00 gsr motor an trans runnin a p28 is the wiring the same as an eg imma wire the vtec driect to ecu from sensors alson gonna wire in the obd2 dizzy in and injectors
Old Aug 11, 2010 | 05:14 AM
sosicksol's Avatar
Default Re: delsol b swap
nice man tell me how it goes im tryna get a sol tmr so maybe you can give me pointers
Old Aug 11, 2010 | 08:17 AM
Sr420Det's Avatar
If all ur componets for the motor are obdII (like the injectors, dizzy, and alt) u should opt for a obdII integra/gsr engine wiring harness, everything will be plug and play. Both sides of the integra harness will plug directly into ur delly on the shock towers and obviously all sensors will plug right in. There is no need to wire anything besides vtec. Ul also need a integra t bracket and integra shift linkage and axles
mudko3
Feb 10, 2014 05:48 AM
HondaLove517
Nov 21, 2008 06:09 PM
bmoney
Aug 13, 2006 01:36 PM
DRKSol
Jul 17, 2006 11:48 AM
SHG_EasyE
22
Nov 7, 2005 05:39 PM
