H22A swap HELP MAP SENSOR and vacuum hoses
Old Aug 10, 2010 | 04:56 AM
brian8702's Avatar
Default H22A swap HELP MAP SENSOR and vacuum hoses
Ok i got a 92 honda accord i swapped it with a h22a .
I need some help with my vacum lines.
i've found different diagrams but it dont help with what my problem is.
i got everything hooked up besides the most of the vacuum hoses.
im confused if i should use the black box that is located near the firewall and the fuse panel. and also with the map sensor. the h22a has the map on the tb and i have mine on ghthe firewall. where do i hook up the map vacuum hose to?
im a lil confused if some could help me or send me a picture of thier swapped h22 in thier cb7 on the vacuum hoses that would be awesome
Old Aug 10, 2010 | 06:59 AM
oneprelude's Avatar
Default Re: H22A swap HELP MAP SENSOR and vacuum hoses
just plug it up, it won't need most of them.
brian8702
Jan 2, 2011 10:20 AM
brian8702
Aug 9, 2010 10:50 PM
JdmCIVIC853
Apr 16, 2003 09:27 AM
boosted1993fd
Mar 2, 2002 05:36 PM
