Is my GE block still good?
Old Aug 9, 2010 | 10:07 PM
dwarfsinhondas's Avatar
Default Is my GE block still good?
As you can see from the pics taken from the bottom up, my cylider has 2 notches in the cylider wall about 5/8ths of inch long. This is b16b with 84mm bore GE iron sleeves and I am wondering what I could do to repair this?
Old Aug 9, 2010 | 10:23 PM
david974's Avatar
Default Re: Is my GE block still good?
it should be good
just do a notching job with a dremel like on the D16 block when you put aftermarket rod
your machine shop could do it for you if you are afraid of DIY
Old Aug 10, 2010 | 03:18 AM
SD_Lurker's Avatar
HT White Ops
Clean it up and its good as new.. Make sure it doesn't have any ruff edges..
Old Aug 10, 2010 | 06:38 AM
ITR-EKcoupe's Avatar
yup not a big deal at all. jus clean up any burrs an itll be golden.
Old Aug 11, 2010 | 09:44 PM
Thanks Guys thats good news!!
Old Aug 12, 2010 | 12:20 AM
joppe's Avatar
Yes dremel it or use air pressure grinder.. I have done 3 d series blocks and all good.. Like this: http://www.theoldone.com/articles/d_...0Block%202.jpg
nano1589
Sep 13, 2011 05:08 AM
LUXXXX
Aug 16, 2006 08:16 PM
wpgcivic
Oct 16, 2004 04:50 PM
_Endless_
Mar 11, 2004 06:37 AM
Turbo_Teg
Dec 24, 2002 05:56 PM
