Is my GE block still good?
As you can see from the pics taken from the bottom up, my cylider has 2 notches in the cylider wall about 5/8ths of inch long. This is b16b with 84mm bore GE iron sleeves and I am wondering what I could do to repair this?
Re: Is my GE block still good?
it should be good
just do a notching job with a dremel like on the D16 block when you put aftermarket rod
your machine shop could do it for you if you are afraid of DIY
Yes dremel it or use air pressure grinder.. I have done 3 d series blocks and all good.. Like this: http://www.theoldone.com/articles/d_...0Block%202.jpg
LUXXXX
08-16-2006 08:16 PM
