my rpm's are going crazy
Old Aug 9, 2010 | 07:40 PM
GrenadaK20's Avatar
Default my rpm's are going crazy
Hey to my OBD1 folks, my 93 si with an LS is acting really weird, it has very little throttle response and when I can get it goin, the engine bogs out and the rpms are slow to climb, when they do climb the tach needle doesnt smoothly rise it gets really jumpy/twitchy....... any thoughts or ideas?
Old Aug 9, 2010 | 07:44 PM
tjdmcoupe's Avatar
Default Re: my rpm's are going crazy
try your distributor,possibly oil in it or bad coil, cap, or rotor.
Old Aug 9, 2010 | 07:48 PM
GrenadaK20's Avatar
they're all new lol ill see check em out though
Old Aug 9, 2010 | 07:50 PM
Former User's Avatar
Any CEL codes? The tach signal comes from the igniter unit inside the distributor, so it may be wise to test it.
Old Aug 9, 2010 | 07:51 PM
tjdmcoupe's Avatar
well your tach runs off your distributor, and loss of power and bogging out can also be caused by your distributor, i had a 94 hatch that pulled the same **** and i swapped the cap rotor and wires, and the problem went away.
Old Aug 9, 2010 | 08:01 PM
GrenadaK20's Avatar
well dizzys a new reman, new cap, rotor and plugs but not wires. no cel's either
GrenadaK20's Avatar
just checked the cap alls well no oil or anything
Old Aug 9, 2010 | 08:06 PM
Remanufactured distributors can be very risky. If the plug wires are old, they could also contribute. Have you replaced the fuel filter?
Old Aug 9, 2010 | 08:09 PM
GrenadaK20's Avatar
new fuel filter and fuel pump, and new fuel relay ughh
GrenadaK20's Avatar
ill try new wires tomorrow
Old Aug 9, 2010 | 08:11 PM
Does the CEL work?
Old Aug 9, 2010 | 08:13 PM
GrenadaK20's Avatar
yeah the only time ive ever seen it come on is while driving it for a while, it'll pop on, any ideas on that lol?
Old Aug 9, 2010 | 08:15 PM
That means a CEL code(s) is thrown. The next time the CEL turns on while driving, pull over and jump the service connector with the engine still running. This will ensure that you recover the code.
Old Aug 9, 2010 | 08:21 PM
GrenadaK20's Avatar
yeah thanks i could never think of how to check it after i turn it off.
Old Aug 9, 2010 | 08:31 PM
You can find that useful tip in the CEL sticky up top.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Aug 9, 2010 | 09:22 PM
GrenadaK20's Avatar
lol i know how to check it, just when the one comes on after driving, it goes away when i shut off, but thanks. pray for me as i try the plug wires tomorrow lol
Old Aug 9, 2010 | 09:56 PM
While the plug wires may need to be replaced, they are not the cause of the CEL.
Old Aug 9, 2010 | 11:19 PM
GrenadaK20's Avatar
Oh yeah I forgot to mention that when I do get it going, I guess you can call it a sputter, it sputters and sends a putt through the exhaust, its not exactly like a backfire...
Old Aug 10, 2010 | 07:05 PM
GrenadaK20's Avatar
What up folks, I went and bought some wires, but they didn't do a thing..
Old Aug 10, 2010 | 07:44 PM
CEL code?
Old Aug 10, 2010 | 10:22 PM
GrenadaK20's Avatar
and none, i love this lol
Old Aug 11, 2010 | 07:44 PM
GrenadaK20's Avatar
any thoughts???
Old Aug 11, 2010 | 08:05 PM
GrenadaK20's Avatar
almost tempted to get my timing done.
Old Aug 19, 2010 | 07:45 PM
97 civic lsvtec's Avatar
i had the same issue i replace everything out there my last thing was the ign coil it fixed the issue awsome
usafhanda
Mar 14, 2012 10:29 PM
Manny-EF
Jun 27, 2010 08:34 AM
pdc125
May 15, 2005 02:26 AM
sincityEX
Nov 7, 2004 07:38 PM
draco067
Jun 21, 2003 12:23 AM
