Loose ECT sensor connector
My ECT senor, single pin connector, the one that's under the distributor, is super loose to where my coolant gauge needle bounce to every bump on the road.
I want to avoid cutting the wire to the connector, any suggestions?
maybe take off the connector, and with a small pair of pliers squeeze it gently, then reconnect it. the only other way is to cut it and put on another fitting (female).
honestly those connectors get brittle and break eventually. snip off the connector, strip some of the wire and use a red (22-18ga) butt connector as a new connection. fits perfectly over the sensor.
Thanks!
carpenterkyle
Nov 3, 2012 07:45 PM
foress_89
Jan 15, 2008 03:58 PM
