to those who have swapped h22's in a eg
i have been purchasing parts to do the swap into my 95 ex. i am going to list all the parts i have already purchased and would like to know if their is anything that i have forgotten or didnt know about.
jdm h22a w/ lsd trans and shifter w/cables
hasport motor mounts
innovative alternator relocation bracket
hasport axles
p28 ecu chipped and socketed w/ p13 basemap. knock,egr and iab's removed
twin core rad w/ slim fan
ac autotechnic fuel rail
h22 rad hoses
custom braided ss clutch line and fittings 7 inches long
non swap related....
energy suspensions full bushing kit
oem trailing arm bushings
fidanza short shift adapter
koni str 8 struts/shocks...keeping stock springs for now
oem front upper control arms
new autozone lower ball joints and tie rods
rear disc conversion from a delsol w/ new pads and rotors
need to get but havnt.....
new front pads and rotors
40/40 prop valve and mc/booster?
stainless steel hard lines.
im sure their are things im forgetting but please list anything im missing for the swap please. ive searched till my fingers and eyes bled. so if i missed it lt me know, it wasnt for lack of searching
adam jeffery
hasport axles
h22 rad hoses
adam jeffery
I might even be having a swap done in a few weeks. ( i say that because i've never done it, and there is somebody that i have met and they sounded like they wanted to help, but i have a feeling i suck and wont be much use wiring wise =[ )
You have your braided lines and fitting, is that for the fuel rail? the jdm engine goes out the wrong side, and you need either an f22 fuel rail ( old honda accord db8?- ~1991 ) or you need some fittings.
I am going to get an inline fuel filter.
Walbro 255lph fuel pump ( I guess it is a 30min install, pretty durn easy)
^ not necessary, but i have heard $80-100 shipped. Your stock one is old ibet xD
Make sure you have your flywheel/clutch and maintenance parts ( timing belt, pump, some other stuff? plugs/wires, etc!>!? )
and the stupid plate that I do not have ( !! bottom plate that bolts under the transmission to the engine! )
Those are the things that stand out to me. The rest i will realize when I go to install i guess =[
the braided steel line is for the clutch. i have an ac autotechnic fuel rail to take care of the fuel rails opposite side inlet.
ive been looking into clutch and flywheels but havnt found what im looking for yet. i already have maintenance items as well.
i wont be doing the swap until my body man is done. needed new qtrs and rockers. so hes doing that and custom paint once the body work is done.
thanks for the response.
adam
adam
I'm having problems deciding on both what parts I need, and what to go with...
Sort of leaning toward a Mishimoto radiator but I want a dual core and aluminum with a fan also.
My friend recommended any sort of street clutch that should be enough. He said a few track runs with a stock clutch on a gsr and the clutch would slip. So I wouldn't recommend stock i suppose.
The intake i'm going with
Intake
$30 blox velocity stack 2.5in/6in
Blox 6" air filter or RF-1048
$40 blox air filter
$50 ebay intake
Intake cost = $120 shipped
Or just some temporary setup for now, we'll see.
I hate this parts shopping game. most of the sponsors do not post prices, can be very annoying!
I need somebody to tell me to get stuff like
Go for an ACT Street clutch /pressure plate and stay with a stock flywheel because its pointless unless you are turbo'ed
and go with a half sized radiator or go with a full sized because ... aluminum? dual core?
Kind of all silly since i have not swapped stuff.
Intake
$40 blox air filter
$50 ebay intake
Not to hijack this thread but I have a quick question regarding the same swap I'm doing into my 95 hatch.
Will the OBD2 throttle body off an H22 work on my OBD1 H22? Would save me some time since it has the map sensor right on it as opposed to the standard one which is on the firewall.
Thanks
Thanks
dschybrid
Appearance Build Threads
641
May 27, 2014 10:18 AM
ezza
16
Dec 30, 2005 06:21 PM
paragus
Jun 28, 2003 07:43 PM
