Will 87mm headgasket work for 87.5mm bore?
I have a 87mm headgasket and I needed to hone out to 87.5mm.
I was wondering if the 87mm gasket will work.
Its such a small difference but i dont want it to fail.
H22 arias pistons low comp. darton sleeves
turbo looking for around 15psi
let me know, thanks
let me know, thanks
An 87mm headgasket will be just over 87 mm but not quite 87.5mm, but it will work for your goals. Your best bet is to measure the id of the headgasket with a set of calipers. Give me a call for more info. Good luck with your setup!
I have the kaizen balence shaft remove kit on my H.
So your saying it will still be good? I thought it would be but ya i was going to measure the gasket and see if it will fit.
