Head gasket question.
Old Jan 26, 2011 | 10:58 AM
No_Limits_Accord's Avatar
Default Head gasket question.
Will a 90mm h22 headgasket work on a 89mm bore? Purchased one advertised as 89mm but showed up it was 90mm. Guy says it should work but if i dont feel comfortable i can ship it back. told him i would ask the professional first haha. So here i am. Any info would be appreciated.
ps. setup is a 89mm darton sleeved block, cp pistons, pauter rods, p&p'd head.
Old Jan 26, 2011 | 12:29 PM
b16bri's Avatar
Default Re: Head gasket question.
I'm gonna say NO a 90mm is for a 90mm not a 89 return it and get a 89mm
Old Feb 1, 2011 | 12:58 PM
zaeta84's Avatar
yes ship it back ,,,and get 90mm
Old Feb 1, 2011 | 03:33 PM
Golden Eagle's Avatar
If you're running a turbo, you should get the correct bore size gasket. If you're N/A, the size difference isn't that bad, the gasket should hold up.
Toanz
Engine Machining & Assembly
Apr 3, 2016 08:12 PM
slow_ls
Aug 23, 2007 02:12 PM
preludefien
Jun 28, 2007 02:05 PM
Rspec CX
Apr 16, 2004 08:10 AM
forcedaccord95
Jan 29, 2003 07:29 AM
