Accord Wont start Try your Luck Two Mechanics and my self and no luck!
Try your magic at the Amazing No start Accord
Car is a 91 Accord with an f22a6 from a 92 accord.
I have been working on this car for a week now. Started a week ago. Got in the car. Started it. Gave me a little trouble to start but finally did. I put it in in gear moved out of my parking spot about 20 foot and the car died and refused to start back. I have Replaced, the following and checked and made sure they are working
Plugs
Wires
Distributor
Resistor Box
Main Relay
ECU
Igntion Switch
I have removed the fuel line from the fuel rail to insure fuel pump was running. It is gas is flowing good.
I have checked all the grounds 5 times over
I have Checked the timing twice. Its Dead on
I have checked to see if the injectores are clicking, even pulled them and turned it to see if they would spray fuel, they did.
Checked my spark Its great
I even went as far as to drain the gas tank and put clean fuel in it thinking i had waterd down gas. No luck
If I pour Gas in the intake and start it car will run until it burns off. So im pretty sure its a fuel problem not sure where to start i have checked all the possble things everything apears to be working.
I have had two shops look at it neither can find the problem.
Plugs
Wires
Distributor
Resistor Box
Main Relay
ECU
Igntion Switch
check the ground wire by the thermostat. Also check the ecu fuse under the hood. And also swap of the ecu with a known good one and see if that works.
Do u have an adjustable fuel pressure regulator or stock fuel pressure regulator.
"I have removed the fuel line from the fuel rail to insure fuel pump was running. It is gas is flowing good."
What is/was the pressure?
I dont have gauge to check teh Pressure but Yes I did remove the Line and it looked like it was flowing really good.
Have u performed a compression and leak down test.
Also when turning the engine over to start have u tried wot start and does anything different happen.
Would could be problem is the fuel pressure regulator might not be supplying enough pressure to allow engine to run. Try starter fluid to rule this out of the equation. If it runs' it has to be fuel pressure or pump related.
And also try full advancing the distributor.
"If I pour Gas in the intake and start it car will run until it burns off. So im pretty sure its a fuel problem not sure where to start i have checked all the possble things everything apears to be working. "
The OP states it will run with "added" feul so that is why I, like you, are leaning towards the fuel pressure.
Change the fuel pressure regulator might not be getting enough fuel. U need a fuel pressure guage that will let u know for sure and give u a good real world reading.
hannan44@gmail.
May 18, 2017 01:28 AM
Squatch
Sep 18, 2013 11:57 PM
jlaley97flstc
Jul 9, 2013 04:14 PM
