1994 civic speedometer issue.
so my speedometer no longer works.
i just put the engine back in the car after a rebuild,
and now it doesnt work.(worked before the motor was pulled)
i had a gsr swap before aswell.
ive tried a new vss,
a new cluster,
running a signal wire to the ecu/vss/cluster,
ive cleaned the pins connecting to the vss,
ive checked all of my fuses,
and still nothing.
i did remove the cruise control module from under
the driver side of the dash if that has anything to do with it,
but i cant find it to throw it back in for troubleshooting.
any help is appreciated!
thanks.
a new cluster,
and still nothing.
thanks.
okay but i installed the stock cluster in and still didnt work.
(ive been running a jdm eg8 cluster for the longest time
and had no problems)
You've already replaced the VSS three times. What are the chances that all are bad? In addition, a bad VSS would typically throw code 17. Be a detective and don't ignore obvious clues. If the VSS and speedo/cluster are good, then logic dictates that there is a bad wire or connector.
Love-MY-honda
12
Feb 25, 2011 08:56 AM
