will i be okay for JRSC build
Old Aug 9, 2010 | 09:49 AM
migrod1's Avatar
Default will i be okay for JRSC build
so i got a couple questions before i go ahead with installing a JRSC on my civic
set up
2000 EM1
63,000 original miles
motor runs strong no issues what so ever
original clutch and doesn't seem to slip
  1. will my clutch slip or hold up?
    do i need to upgrade to stage 1
  2. do i need new timing belt and tensioner
  3. do i need a new water pump
build will consist of the following
JRSC kit with 8psi pulley
rc440
hondata s200
Old Aug 9, 2010 | 12:18 PM
migrod1's Avatar
Default Re: will i be okay for JRSC build
BUMP
Old Aug 9, 2010 | 02:23 PM
I CRX I's Avatar
1. it will not hold up for long
stage 2 or higher.
2. No.
3. No.
Old Aug 9, 2010 | 09:01 PM
migrod1's Avatar
bump any more advise
Old Aug 12, 2010 | 12:52 PM
migrod1's Avatar
anyone know if a stage 1 exedy organic clutch be able to handle a 8psi JRSC on a B16a2?
Old Aug 16, 2010 | 03:42 PM
civicH22TypeS's Avatar
Do as I CRX I said. Stage 2 or high
Old Aug 16, 2010 | 03:52 PM
2kdrift's Avatar
1. why supercharge?
2. why stage 2 ? i have a stock clutch on my turbo d16 if i wanna burn rubber it grabs,(maybe not as much as more race types) most teh time im driving regular and it works just fine
Old Aug 16, 2010 | 04:15 PM
95itr-ej2's Avatar
seems your car has 63,000 original miles the timing belt should of been changed before if not then change it even if you dont super charge it
as for the clutch, if it's the original clutch in the car since it came from the factory then chances are it wont hold up for long if super charged.
hope this helps
Old Aug 16, 2010 | 04:23 PM
2kdrift's Avatar
hope this helps
true dat, but he dont necessarily need stage 2 clutch.i like the stock exeddy clutches they work well
Old Aug 16, 2010 | 05:20 PM
95itr-ej2's Avatar
stock exedy are a good kit but i find F1racing stage 2 good, I have 1 in my b18c Itr motor ej2 coupe the past year with no problems so far and its not stiff like some other stage 2 clutches i'v used
Old Aug 22, 2010 | 03:16 AM
yeah, supercharge different turbocharge. Supercharge much fast spin with belt at first rpm compare turbocharge wait for spool up at end rpm. but if both high power then high clutch. So My turbo gsr 300hp with stock clutch. If my supercharge then high clutch
Navy_CRX
Mar 24, 2010 07:32 AM
Smulude
Jul 2, 2004 10:22 PM
Smulude
Jul 1, 2004 08:03 PM
spark
Apr 28, 2003 03:23 AM
