will i be okay for JRSC build
so i got a couple questions before i go ahead with installing a JRSC on my civic
set up
2000 EM1
63,000 original miles
motor runs strong no issues what so ever
original clutch and doesn't seem to slip
build will consist of the following
JRSC kit with 8psi pulley
rc440
hondata s200
set up
2000 EM1
- will my clutch slip or hold up?
do i need to upgrade to stage 1 - do i need new timing belt and tensioner
- do i need a new water pump
rc440
hondata s200
Re: will i be okay for JRSC build
seems your car has 63,000 original miles the timing belt should of been changed before if not then change it even if you dont super charge it
as for the clutch, if it's the original clutch in the car since it came from the factory then chances are it wont hold up for long if super charged.
hope this helps
hope this helps
hope this helps
hope this helps
stock exedy are a good kit but i find F1racing stage 2 good, I have 1 in my b18c Itr motor ej2 coupe the past year with no problems so far and its not stiff like some other stage 2 clutches i'v used
yeah, supercharge different turbocharge. Supercharge much fast spin with belt at first rpm compare turbocharge wait for spool up at end rpm. but if both high power then high clutch. So My turbo gsr 300hp with stock clutch. If my supercharge then high clutch
Navy_CRX
03-24-2010 07:32 AM
