Door Mirror Replacement on 99 V6 EX
Old Aug 9, 2010 | 02:13 AM
Danny.T's Avatar
Default Door Mirror Replacement on 99 V6 EX
My 99 V6 EX right door power mirror somehow not working (power mirror switch working fine on the driver side). I'm thinking to get one from the junk yard, but not sure it will match the color, so I want to swap the inside electrical mechanism into my old mirror housing, saving the color. Can you help me how to do it? Please...
Any help would be very gratefully appreciated
Danny
(This's my young son car, but my money)
Old Aug 9, 2010 | 05:53 AM
sgraham01's Avatar
Default Re: Door Mirror Replacement on 99 V6 EX
Make sure you really need to go through this before you do. Test the mirror out and the control circuit to be sure you need to go thru this much trouble.
Remove the mirror from the car. there should be an access hole under the mirror body. loosen the screw, but don't remove it. this allows the mirror glass to be tilted out of the housing. Once you have the glass out, it will probably still be attached to the body by the wiring. you should now be able to see the screws that hold the halves of the mirror body together. Once you take these screws out you should be able to get the body apart. If you can't get the harness pulled through the mirror body, you may need to cut it and splice it back together in the new mirror.
visit hondapartsnow.com for an exploded view of the mirror parts.
Old Aug 9, 2010 | 07:37 AM
Danny.T's Avatar
Thank sgraham01, I will do that.
Old Aug 9, 2010 | 09:12 AM
sgraham01's Avatar
i took a look at hondapartsnow, and it looks like you can order the actuator assembly for about $30. That would be a better repair, since the part would be new for about the same money (maybe less) as a used one.
Old Aug 25, 2010 | 02:02 AM
Danny.T's Avatar
Thanks sgraham01, done, the center knot on the the actuator assembly was broken, the owner hot glue the mirror to it. I replaced the actuator assembly.
Danny
Old Aug 25, 2010 | 05:27 AM
sgraham01's Avatar
good to hear you got it done. I did something similar a few months back on an 01 Malibu to save the painted mirror head. It's definitely worth the trouble to not have to paint it.
integratyper1990
10
Aug 24, 2011 09:36 AM
JDMxEKxH22
Apr 17, 2009 05:09 PM
Libertariat
Nov 16, 2006 07:52 AM
ella94
May 16, 2006 10:57 AM
bzyrice
18
Dec 22, 2005 05:29 PM
