I have lost V-TEC. Can someone help me???
Old Sep 16, 2002 | 06:46 PM
MyWhiteCivic's Avatar
Default I have lost V-TEC. Can someone help me???
OK, I was going over some of my datalog files and I realized that I never hit V-TEC. In it's place, I'm getting a V-TEC pressure code (code 22 on my P28 ECU). That's why my car is so damn slow. So can anyone help me? The code first starting happening when I put the turbo on and was going very fast. full throttle at 80 mph I throw the code but I'm not getting V-TEC before that either. Can someone help me? Did I tap vacuum in the wrong place? I have no idea what I did wrong. Please help.
BTW, my VTECH phone is working fine so that will save some of you guys some time.
Old Sep 16, 2002 | 07:32 PM
rjardy's Avatar
Default Re: I have lost V-TEC. Can someone help me??? (MyWhiteCivic)
what is V-TEC?
i know that vtec is what honda offers as variable timing.
Rob
Old Sep 16, 2002 | 08:37 PM
inline976's Avatar
did you add another quart of oil?? or a half a quart?
Old Sep 16, 2002 | 08:41 PM
crzsomang's Avatar
Default Re: I have lost V-TEC. Can someone help me??? (rjardy)
It's not vtec either...
It's VTEC (all caps)
[Modified by crzsomang, 5:42 AM 9/17/2002]
Old Sep 16, 2002 | 10:10 PM
rjardy's Avatar
Default Re: I have lost V-TEC. Can someone help me??? (crzsomang)
riiiiiiiggghhhhtt
Rob
Old Sep 17, 2002 | 03:13 AM
Default Re: I have lost V-TEC. Can someone help me??? (inline976)
Would I need that? Not enough oil pressure? I'm serious guys. My car is extremly slow for having a turbo. Please help.
Old Sep 17, 2002 | 06:21 AM
VTC_CiViC's Avatar
Lost your VTEC? Hmm.. check between your seats, I know mine always falls in there
No really, check your oil level, you might be running low.
Old Sep 17, 2002 | 07:16 AM
sleepercivic's Avatar
Default Re: I have lost V-TEC. Can someone help me??? (VTC_slow_CiViC)
Check your wires the could be bare in a spot and have shorted the solenoid out, also your ecu could be bad i had a bad one, or maybee you VTEC solinoid is clooged take it off and look at it
TERRY
Old Sep 17, 2002 | 07:39 AM
TurboDX's Avatar
Default Re: I have lost V-TEC. Can someone help me??? (sleepercivic)
If you are running fish tank check valves then get rid of them and get the missing link.....when ever your check engine light comes on your car is in safe mode so VTEC wont kick in....for the fish tank check valves you might not have enough...if you are not running check valves then ohm out your VTEC solinoid to see if it is bad......just some thoughts
Old Sep 17, 2002 | 07:47 AM
Default Re: I have lost V-TEC. Can someone help me??? (TurboDX)
I don't use check valves or a missing link. I have Hondata. Thats how I found out which code it was.
How much oil do you guys think I should put in over the normal amount?
Thanks VTC_slow_CiViC, but no luck. Maybe I left it in the house.
Old Sep 17, 2002 | 07:52 AM
DSF's Avatar
DSF
"0" If your oil level and pressure are normal there should be no need for more oil. Check the solenoid wiring. Make sure you have continuity back to the ecu. Check the solenoid itself, too. Also, I did know one other person with a Hondata unit who ended up with mysterious codes (meaning the hard parts checked ok). Ended up being a bad ecu.
My $.02
Old Sep 17, 2002 | 07:57 AM
Default Re: I have lost V-TEC. Can someone help me??? (DSF)
I'm going to pull off the solinoid tonight and check it. I'll check the wiring while I'm there. I'll post later on tonight.
Old Sep 17, 2002 | 09:18 AM
MachAF's Avatar
My $.02
Wouldn't he need to add more oil because of the oil that goes to the turbo?
Old Sep 17, 2002 | 09:22 AM
DSF's Avatar
DSF
Default Re: I have lost V-TEC. Can someone help me??? (machaf)
Not really because it's a very minimal amount.
Old Sep 17, 2002 | 11:20 AM
Kamin's Avatar
http://209.209.25.36/zerothread?id=164863
Old Sep 17, 2002 | 12:55 PM
rjardy's Avatar
Default Re: I have lost V-TEC. Can someone help me??? (KAMiN)
Very nice Kamin
Rob
Old Sep 17, 2002 | 04:24 PM
Kamin's Avatar
yea i was REALLY REALLY bored one night
and there were like 13 threads that week about how people vtec werent working
Old Sep 18, 2002 | 10:05 PM
nickb20vtec's Avatar
check all vtec lines and make sure everything is connected with the ecu.
Old Sep 28, 2002 | 06:53 PM
Jago's Avatar
Default Re: I have lost V-TEC. Can someone help me??? (nickb20vtec)
You might just have a bad VTEC pressure switch.
thats what a code 22 is.
Old Sep 29, 2002 | 11:29 AM
Default Re: I have lost V-TEC. Can someone help me??? (Jago)
Do you know how to fix that? What should I do? I called Hondata and they said it can't be a problem with the ECU because if it was, the code wouldn't show. How do I check for a bad V-TEC pressure switch?
ganjasnack
Jun 11, 2007 02:38 PM
slowr6
Mar 27, 2007 04:51 PM
Dr3w92civ
Apr 19, 2006 12:03 PM
dkboyny11
Jun 2, 2005 03:45 PM
