Built/Boosted K24 EM1
Motor/Tranny
K24a2 block
K24a2 head stock
bc rods
cp 9:1 pistons
ARP headstuds
Precision 1000cc
stock clutch
RSX-S tranny
Turbo
ASP turbo kit & manifold
GT35R turbo .82ar
50mm bov
44mm wastegate
stock map sensor running 8-10psi
Motor was built and tuned by Stefan at ASP. Tuned on 92 octane
car made 410whp and 282wtq with stock clutch :/
This summer im hoping to get a twin disc and lsd in with a 4bar map sensor and then do some boost by gear tuning.
here is the dyno from my most recent tune done by Stefan
here is a video my buddy made of us doing some freeway pulls
YouTube - ‪350hp k20 turbo vs 400hp k24 turbo‬‎
in the vid he had a built k20, piston/rods/cams, Twin Disc, GT35R, custom ASP turbo kit, stock map sensor so only on 8-10lbs too, partially dyno tuned. also has ep3 5spd trans. He was falling out of boost in 4th gear every time, thats when i would pull hard on him
he now has a 4bar map sensor and made 435 on shitty tune on 15lbs of boost. Were gunna get another vid of some more pulls when he goes back to the dyno for more tuning on more boost.
here are a few pics of my setup
here is also an older vid i made from when my car was N/A
http://www.youtube.com/watch?v=klwOUNb7kSg
Once i get my twin disc, lsd, and boost by gear tuning done, ill make a good vid of some pulls, fly bys, races etc.
enjoy!
K24a2 block
K24a2 head stock
bc rods
cp 9:1 pistons
ARP headstuds
Precision 1000cc
stock clutch
RSX-S tranny
Turbo
GT35R turbo .82ar
50mm bov
44mm wastegate
enjoy!
well a mod can move it to where it belongs then, i didnt know where to post it up. this seemed like the most logical place.
if you really wanna see progress made, you can read through this
http://www.k20a.org/forum/showthread.php?t=37329
thats my buddies car, i have the black coupe, idk if you could tell between the pics and the vids. He doesnt need an alignment tho, he just put his steering wheel on in a hurry so he didnt put it on straight. it is however on straight now.
Well since BOTI is just a few weeks away i thought i would update this a little bit.
Im hoping to have a CC twin disc and Mfactory LSD in by BOTI, along with some more boost and tuning. Work is slow right now so im not sure if thats gunna happen. but i got my fingers crossed.
But i did pick up some new back seats today since i planned on running street class.
Some 08 civic si rear seats. Fit pretty damn good. Had to do a little modification to them to meet my satisfaction tho.
Ill get some pics up tomorrow of them installed, along with what i did to make them workout a little better
ere are some pics of the seats, and their fitment. didnt take them out to get pics of what i modified, but i will probably tomorrow, still have a few things i wanna do to make them perfect tho.
The reason this looks crooked is because i shoved it over to get the back piece to lock in, eventually i will adjust it over about an inch so the back will sit flush.
I finally got a twin disc in, also installed an ASP catch can kit and a 4bar map sensor. I have a boost solenoid still waiting to be installed, but havent had the time yet. Onto the pics.
