LS Vtec Issues...Please Help Out!!
Old Aug 7, 2010 | 02:00 PM
NOTDISFA5's Avatar
Default LS Vtec Issues...Please Help Out!!
I was wondering if somebody can help me out. I put a b16 head into a LS block and did the whole set up with the LS vtec kit, tapped the hole on the head, changed the headgasket. Now the car starts up but im lost now because after a minute or two the radiator starts shooting up oil and anti freeze mixed up together like mud. The only thing i can think of is that its the head gasket but its brand new and it sits right. If somebody has any info on what it could be please post it up. Thank You
Old Aug 7, 2010 | 02:04 PM
em1effekt's Avatar
Default Re: LS Vtec Issues...Please Help Out!!
wich head gasket did you use?
Old Aug 7, 2010 | 02:12 PM
NOTDISFA5's Avatar
Ls vtec head gasket. Cost me 90 bux. Now i think i might know what the problem is. I noticed that who ever had the head last didnt do a good tap. On the the outter wall of the head where the oil hole is that gets tapped i looked in and i noticed there a second hole on the bottom of the second wall at the bottom. Could it be that the person who had the head before me drilled a hole into the oil hole and then drilled a second hole into the bottom wall by accident and thats why the oil is mixing up with coolant?
Old Aug 7, 2010 | 03:29 PM
NOTDISFA5's Avatar
bumppppppppppppppppppppppp
Old Aug 7, 2010 | 03:57 PM
D16SiHatch's Avatar
i'm sure that made some sense in your mind but it doesn't now that you've typed it out lol.
pics would help of what you're describing.
Old Aug 7, 2010 | 07:56 PM
TheStig187's Avatar
wow thats why u dont buy heads that have been port or taped for lsvtec, the last person probly did mess it up. was the ls motor running with no problem prior to the lsvtec?
Old Aug 7, 2010 | 08:01 PM
DVDr's Avatar
Best thing to do as stated above, is to take pictures when you are trying to describe something.
picture of head just in case you dont have camera.
Old Aug 8, 2010 | 01:24 PM
98greensi's Avatar
i would say you put the head gasket on upside down, if this stared right from the start. i dont know for sure but a shitty tap job would cause a oil leak but i dont think it was cause oil/antifreeze to mix
Old Aug 8, 2010 | 08:02 PM
em1effekt's Avatar
check the head gasket...and make sure your head matches the pic they showed above
and let us knoww
blk90teg
Feb 14, 2007 08:53 PM
pulgaleakimports
Sep 14, 2004 02:06 PM
Chuji
14
May 18, 2004 05:03 AM
CRXGSR
Mar 11, 2003 09:28 PM
