b16 wont stay running because of IACV?
I have a 97 sedan dx wit a obd2 b16 swap and a 96 obd2 gsr ecu. Ran fine till I got off work and started the car. Idle lobed 2 or 3 times then died. Now it won't start or run unless my foot is on the gas. Never had this problem before. Code 14 cel. Any ideas would be geratly appretiated. Thanks all.
Some auto parts stores will pull OBDII codes for free. The specific code will help you pinpoint the troubleshooting.
If you reset the ECU, does the same code return?
After the engine starts, does it run fine?
Okay, so it's just an idle issue. Pull the OBDII codes and post them. Did you already clean the IACV? Is the IACV plugged in? What color are the wires that run to the IACV plug?
thenks for all your help. And bearing with me through that confussion lol. I will try cleaning it and if that dosent work I will post the code from the reader tomorow
If someone can help i would really appreciate it. I posted here because i am new and not sure where to post my own thread but this is almost the same question so tried here first.
