bad oil pump
Old Aug 5, 2010 | 11:41 AM
sensasian03's Avatar
Default bad oil pump
can a bad oil pump cause a knocking sound in the the bottom block?
Old Aug 5, 2010 | 02:36 PM
goldpearleg6's Avatar
Default Re: bad oil pump
a bad oil pump can cause you to spin a rod bearing
Old Aug 5, 2010 | 04:30 PM
so that knocking sound from the bottom could be a spinning rod bearing? i know my oil pump is bad because the oil pressure light starts blinking after idling for while and goes away when rpm goes up. and there a leak when i keep revving, looks like its coming from the oil pump/oil pan gasket area. would changing the oil pump eliminate that rod bearing sound? or my block is completely bad and have to replace it along with the oil pump? im trying to find the cheapest way to fix it. dont have the budget to do a complete swap right now.
Old Aug 5, 2010 | 04:38 PM
here is a video of the sound
http://www.youtube.com/watch?v=pKt4N9ZrW6Y
Old Aug 5, 2010 | 06:20 PM
actually i looked at alot of bad rod bearing video and my car doesnt sound like that knocking sound. its more of a grind/rattle. it could be something else rather than the rod bearing. anyone else could help me figure this out?
Old Aug 5, 2010 | 06:46 PM
minilogoguy18's Avatar
First of all, why are you even driving a car which you know has a shot oil pump? Do you want to ruin the car or something?
Old Aug 5, 2010 | 06:58 PM
come on man common sense of course im not driving the car. just been sitting in the driveway. i need help not someone who make false assumption and to flame me.
Old Aug 6, 2010 | 05:26 AM
Well why not start with the obvious, replace the oil pump, your valves also are pretty noisy, check and adjust if needed. Pulling the valve cover to inspect the valve clearance may also rule out some things that could have excessive wear since H23a1's don't have forced oiling the the valvetrain is the furthest thing from the already bad oil pump.
Old Aug 6, 2010 | 07:46 AM
Apex1972's Avatar
this/\
jlows923d
Nov 18, 2010 01:39 PM
fryguy190
10
Aug 31, 2008 08:13 PM
Dat1BVtecN
Nov 7, 2006 04:23 AM
ThatsMyEG
Aug 15, 2006 01:38 PM
