high comp. b16a
Old Sep 16, 2002 | 04:23 PM
B16b2b's Avatar
Default high comp. b16a
installing ctr pistons (reg. not oversize) and spoon headgasket. what should i look into for ecu programs, fuel pump, and fuel injectors?
Old Sep 16, 2002 | 04:27 PM
B16b2b's Avatar
Default Re: high comp. b16a (1I1I11I)
maybe i can post some high numbers on dyno like that mysterious dyno plot on the mostly "stock" b16a or whatever. haha!!
Old Sep 16, 2002 | 05:00 PM
B16b2b's Avatar
"...i'm the boss...need the info..." -- oh sorry>>>> any help?
Old Sep 16, 2002 | 09:36 PM
B16b2b's Avatar
ttt
Old Sep 17, 2002 | 12:57 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
man, have some bleeding patience!
here!
and do some damn search before you post, m'kay?
stan
Old Sep 18, 2002 | 07:14 AM
TimoneX's Avatar
New User
Default Re: high comp. b16a (90crxsi)
That sounds like a risky combination. I'd check your valve to piston clearance carefully. Is't the spoon gasket around .45mm ish?
Old Sep 18, 2002 | 08:36 AM
CHEETAH's Avatar
I've done it a few times, evne used a GSR head milled 20 thous ... upgrade your fuel pump and go 310cc injectors and it'll run faster than a lot of 1.8s and even some b20/vtec.
pumped a good 12.5 on customer's EG with it.
oh yeah, I have a nice program for the ECU for that combo also.
Greg
[Modified by CHEETAH, 5:36 PM 9/18/2002]
Old Sep 18, 2002 | 01:13 PM
B16b2b's Avatar
maybe i did attempt to research the question, but stopped since people post about forty different topics in each forum per day. MAYBE, be helpful instead of being a JACKASS. i HOPED someone who may have read the post has been in the same plight as i am right now, and would be glad to help a fellow car enthusiast reach his or goals.
GEEZ, why didn't i just think to click <U>HERE</U> in the first place!!! wasn't that stupid??!
[Modified by 1I1I11I, 5:57 PM 9/18/2002]
Old Sep 18, 2002 | 01:18 PM
B16b2b's Avatar
Default Re: high comp. b16a (TimoneX)
i had earlier emailed aj-racing and asked about potential valve clearance issues, and they suggsted that there should be none with that setup. EVEN with the addition of toda B's. so, i guess their word is good enough for me.
Old Sep 18, 2002 | 01:21 PM
chad's Avatar
Moderator
ummm
Old Sep 18, 2002 | 01:22 PM
chad's Avatar
Moderator
yeah....someone lick my CHODE
Old Sep 18, 2002 | 01:59 PM
B16b2b's Avatar
Default Re: high comp. b16a (Chad)
not til you start wiping ***-- ****
Old Sep 18, 2002 | 04:52 PM
EKhatch's Avatar
This is a very simillar set up to the one I am going to run except with .25 over CTR's. Compression should be around 11.5-1 and I seriously dout I am going to have any clearance problems, even with an aggresive cam setup.
crazyguy
Mar 15, 2016 05:49 PM
ninjlao
Jun 27, 2006 06:07 PM
B16Hatchcx
May 28, 2003 08:45 PM
B16b2b
Oct 3, 2002 05:35 PM
91b16a
Mar 27, 2002 12:27 PM
