what kind of pistons to use.
i know there is lot of good once out there but just wanna see what you guys recomend for me to use. i have a ls v tec benson's sleeve and head is stock. i already have some aftermarket rods and just dont know what pistons to use and also what compresion to get. i want around 400whp. what you guys recommend and what to stay away from. thanks.
Go with CP or Arias. Although Arias makes a good product, hopefully you don't get screwed like I did and get sent the wrong rings with the pistons. I rebuilt my motor 3 times trying to diagnose the issue and the problem was they sent me the wrong rings twice! Idiots! Call Elmer... He's the only one that know's what he's doing.
Also, I agree with 1sicef9... Go with 9.5:1. You'll be happy you went above 9. If you can run E85 go with at least 10:1
ya i think i decided to go with wiseco pistons and probally will go with 9. 5.1. but another question i have is the sleeves are gonna be bored out to .40 over the stock and will that bring the cp up? the head is stock and not milled.
For 400 whp I would look at something from 9.5:1 to 10.8:1. The higher compression will help with low end power and you will achieve your HP goals with less boost. It takes more boost to make the same power with lower compression. Look to tune with something like an s300 and e85 fuel.
i would go with e85 but my car is gonna be daily driven and there is not many gas station with e85 over here.
Are you sure a simple ball hone will fix your scratch? Why don't you just spend the $150 to bore it to 84mm and have the block hot tanked so it's perfect and you can paint it. You will enjoy the difference in driving an 84 vs 82mm. It will be noticable.
E85 is much better too. I drove with it in my daily and there was only one station I could get it from. You just have to fill up more often. Up to you...
