Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
07 Accord power plug not working
Old Aug 2, 2010 | 09:08 PM
sneaks's Avatar
Default 07 Accord power plug not working
Dont know where to look. Just bought the car. Was working then stopped
Old Aug 4, 2010 | 09:24 PM
mason46's Avatar
Default Re: 07 Accord power plug not working
Did you check the owner's manual.is there anything given about the power plug.when did it happen?
Old Aug 5, 2010 | 04:04 PM
KWayRacing's Avatar
There are two fuses in the driver's side interior fuse box. Fuse 9(15 AMP) and fuse 32(7.5). Fuse 9 will most likely be blown but before replacing it make sure there is not something down in either accessory socket.. like a penny. If no foriegn object and fuses are blown then replace the fuse and evaluate the device you are plugging into that socket.
Old Aug 6, 2010 | 05:06 AM
johnnykash's Avatar
check to see if the power supply is plugged into the back of the power plug. i went to use mine once, and the prong on the back of the plug had fallen off
Old Aug 9, 2010 | 06:01 AM
jolie12's Avatar
If the power plug is not working,it may be due to loose connection or else its good to go and meet the mechanic,he will give the solution of your problem
user114
Feb 6, 2013 04:17 PM
green eyed bandit
Nov 16, 2011 06:14 AM
nightryder21
Honda Civic (2006 - 2015)
Mar 19, 2009 03:42 AM
strsi
Jan 12, 2008 10:00 PM
2LoW4FaThOeS
Audio / Security / Video
Oct 1, 2005 05:13 PM
