Digtal boost controller install
Old Aug 2, 2010 | 02:08 PM
spoon93's Avatar
Default Digtal boost controller install
Anyone have a diagram on how to install a digital boost controller 91 si hatch ls turbo maybe some pics as well thanks h-t
Old Aug 2, 2010 | 02:52 PM
spoon93's Avatar
Default Re: Digtal boost controller install
Anyone
Old Aug 2, 2010 | 08:28 PM
sanimalp's Avatar
$cat /dev/urandom
Question: how do you intend to compensate for adjustments in boost using your boost controller? or is this a "i don't care if i blow my **** up" situation.
some details would be good. what controller do you have. Why a digital instead of a manual control. Are you running an aftermarket EMS, stock ecu, chipped ecu, turboedit, crome, Ectune, Neptune, Hondata, AEM EMS, Motec..
Old Aug 3, 2010 | 09:17 AM
spoon93's Avatar
Ya sorry bout that I jus ended up goin with turbonetics mbc instead of the electronic one the motor is stock I dnt need anything to fancy I guess is that mbc any good
Old Aug 4, 2010 | 08:31 PM
sanimalp's Avatar
$cat /dev/urandom
I would go with a manual boost controller any day over an electronic. Some things were not meant to be complicated.
Electronic and multi stage controllers have their place, but a mbc will keep you out of trouble if you have to rely on the car for a DD. I think you made a good choice.
Old Aug 4, 2010 | 08:43 PM
spoon93's Avatar
Cool thanks for the info bro also another ques will it be a problem to run it inside of the car rather then under the hood?
Old Aug 4, 2010 | 09:10 PM
sanimalp's Avatar
$cat /dev/urandom
fundamentally, there is no problem running it inside the car.
realistically, you have to realize how bad it will be if you tune your car for one setting (you do plan to get it tuned, right ), and then screw around with it to go faster. I speak from experience when i say the temptation will be far too great to not mess with it, and the engine and your wallet end up getting hurt as a result. At the end of the day, it is up to you,as there is really no technical reason why it cannot be mounted inside the car.
Old Aug 5, 2010 | 07:28 AM
spoon93's Avatar
Ok I see and yes I'm gonna be gettin it tuned in about 2 weeks or so thanks bro
stizzit
Feb 9, 2006 06:17 AM
willahlborn
Mar 26, 2003 11:36 PM
3.3.3
Jan 8, 2002 02:12 PM
DIRep972
Dec 4, 2001 09:57 AM
