IAC valve question
Old Sep 16, 2002 | 01:55 PM
sleepercivic's Avatar
Default IAC valve question
i have a bad IAC valve thus a very bumpy idle, but my MAP, injectors, are throwing a code could this be why, because the idle is so screwed up, alos i have a resister box on the injectors but they work so i must have it wired up ok...right?
TERRY
Old Sep 16, 2002 | 02:42 PM
Spade's Avatar
Default Re: IAC valve question (sleepercivic)
For the IACV.....just put a piece of aluminum between it and the intake manifold and bolt it back down.
That eliminates that issue.
Edit: I used a piece of a beer can.
[Modified by Spade, 3:42 PM 9/16/2002]
Old Sep 16, 2002 | 02:58 PM
Default Re: IAC valve question (Spade)
so i dont need to run an IAC, can anyone else vouch for this
TERRY
Old Sep 16, 2002 | 04:49 PM
hondafrk's Avatar
Come on spade, dont let this guy do things the wrong way.
Most likely the IAC valve is faulty. They are a common problem on older civics and accords. you might be able to locate a used one at a junkyard pretty cheap.
but the other option that Spade mentioned will work too, but its not the right way.
Old Sep 17, 2002 | 04:48 AM
Default Re: IAC valve question (hondafrk)
ok i have a second gen b16 manifold to use so im gonna swap it over
TERRY
muffler man
Jul 14, 2009 02:27 PM
5SpdH22
Apr 5, 2008 10:17 AM
trianglegreg
Jan 10, 2006 04:22 PM
Mr2KiEu
Apr 5, 2005 11:56 PM
