calling all tuners has this ecu been modified
Old Aug 1, 2010 | 03:37 PM
ghostriderinnc's Avatar
Default calling all tuners has this ecu been modified
post deleted
Old Aug 1, 2010 | 03:41 PM
cpl rampage's Avatar
Default Re: calling all tuners has this ecu been modified
that ecu is chipped, that is what the sst chip is. however, there is no neptune RTP board in there.
http://www.hrtuning.com/pages/category/neptune-rtp
Old Aug 1, 2010 | 04:01 PM
so does that mean it was tuned with neptune or not because the guy who tuned it specifically said I purchased a neptune RTP license standard. It looks like one of speed innovations kits?????
Is this the factory ECU or did they swap it over and how do I get rid of it in the future and add hondata
Old Aug 1, 2010 | 04:15 PM
HRTuning's Avatar
There is a standard version of NepTune that uses a chip, but is NOT a NepTune RTP.
Who tuned it? If they're a NepTune dealer, it's likely NepTune. If not, it's not. It's really that simple.
Old Aug 1, 2010 | 05:33 PM
SOHFAST94's Avatar
Originally Posted by ghostriderinnc
I really don't want to say who tuned it. They are a neptune dealer I checked. The car idles really bad and there is a ticking in the head. Mike laskey told me he thought it was the lost motion assembly because the compression test went ok but we then discovered the headgasket seeping oil.
All I want is to get my car fixed and get it off this chip on hondata. I've inspected the plugs and pistons I had my buddy check the AF and it's way off. So if you guys could tell me wether someone can put the car on hondata then I'll get the motor repaired and the oil leak stopped by someone reputable and find a new tuner
Why don't you stay with Neptune? It's really good you know!
Old Aug 1, 2010 | 05:56 PM
HRTuning's Avatar
Yes, you can go Hondata. That won't fix your obvious engine issues, which has nothing to do with NepTune or your current tuner.
Old Aug 1, 2010 | 06:48 PM
yeah I know I'm just irritated. I paid to have my motor built and well I got it back running worse then before I had it rebuilt. Has nothing to do with my current tuner thats why I won't even begin to say who tuned it. Course the AF being off has me a little perplexed but **** happens. Bottom line is the head needs to be repaired and then it needs to be retuned.
Old Aug 1, 2010 | 07:49 PM
HRTuning's Avatar
Definitely. I hope you get it fixed up. NepTune or Hondata will run your setup just fine when everything is up and running.
Old Aug 2, 2010 | 10:43 AM
HRTuning's Avatar
The SST chip is not in a socket?
You could upgrade to the NepTune RTP, be able to log and make changes. As it sits you can datalog if you get a hulog datalogging setup from Moates.net
PM me who the tuner was please.
hood ride eg
Southern California
Aug 30, 2010 01:39 AM
EFboostedSI
Engine Management and Tuning
May 8, 2009 02:48 PM
chicken18
Mar 25, 2009 06:26 PM
B18C_EJ8
Apr 12, 2005 12:07 PM
tdog
Feb 7, 2003 05:21 PM
