fuel/temp gauge and clock no longer working
I noticed that my temp gauge wasn't working and found that the coolant temp sensor was unplugged. I'm not sure if I plugged in the wrong wire or not, but after plugging it in, my clock and none of the gauges/lights on the cluster turned on. I researched through here and it seems like the right wire for the coolant temp is the yellow with green stripe one. I plug that one in and checked all the fuses (under hood and under dash). All the fuses are still good but the none of the cluster lights nor gauges work.
Have anyone had a similar problem and found out the solution? I don't know what else to check. Any help is appreciated.
joshluis
Mar 24, 2008 03:26 PM
pdiddyparsons
Apr 8, 2003 08:52 AM
