getting rid of stock oil cooler h22a
hi
im planing to get rid of stock oil cooler as i have oil pressure issue ,i hope it will help
anyway does anyone nows the thread size of the bolt holding stock oil cooler - side that goes into engine
thanks for fast reply
im sure on 100% is not bearing or oil pump , its fresh built up
problem has started after i installed oil cooler and oil stat both by mocal
at idle when cold the pressure wont exceed 70psi ,when warm its dropping by another 10psi ,the oil stat is installed properly
to make it clear you are talking about this bolt, maybe not particular part number
http://www.n1racing.net/eshop/prod_i...e1ab6653ee.jpg
how much pressure I would gain by using h23 bolt???
thanks
qpe
thanks
qpe
EGgoJDM
Dec 1, 2009 12:05 PM
itr501
Oct 23, 2001 02:41 PM
