SOHC Turbo fuel question!?!?!?
Old Sep 16, 2002 | 10:48 AM
DsMWookie's Avatar
Default SOHC Turbo fuel question!?!?!?
I have a d16 and I have 16g turbo now if I got with the cartech fmu will that saffice or am I going to HAVE to change injectors right away or can I run low boost and be fine till I find a good deal.
Also can I ditch the whole FMU and get v-afc and just use dsm injectors and do it without fmu?
How hard is it to program a v-afc?
[Modified by forward_motion_crx, 4:13 AM 9/17/2002]
Old Sep 16, 2002 | 11:21 AM
genop's Avatar
Default Re: SOHC Turbo fuel question!?!?!? (forward_motion_crx)
If I were you I would get the v-afc and a set of 450cc injectors. That setup is good for about 10-11psi. Eventually you need to get an upgraded fuel pump. I think they are doing a group buy on the fuel pumps right now, I would jump in on that.
Old Sep 16, 2002 | 11:23 AM
ijjz's Avatar
FMU alone should be fine for now, as long as you do not boost alot. Yes you can replace the FMU w/a v/safc and dsm injectors as long as you know how to program it.
laakea
Apr 3, 2006 07:13 PM
DXK Eg
Mar 9, 2004 09:29 AM
slow02ss camaro
Apr 8, 2003 06:50 PM
