Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
please help
Old Jul 28, 2010 | 05:39 PM
mozee82's Avatar
Default please help
05 accord coupe nothing on the steering wheel works ( radio controls , cruise control and horn but horn works for alarm) and i have the airbag icon on just had a trans put in and the steering wheel was doing full 360's while the wheels were not moving had that fixed but now the steering wheel controls are dead don't even light up with headlights is there a wire harness somewhere that isnt connected someone please tell me something
Old Jul 28, 2010 | 06:21 PM
bobinator5000's Avatar
Default Re: please help
Sounds like the wiring in the steering column is not plugged in correctly or was crimped during reassembly.
I've had plenty of mechanics **** up trans jobs before; even when they don't have to go into the damn thing and replace parts. Had one plug the speedometer connector in WITH THE CAR RUNNING and fried the speedo.
Old Jul 28, 2010 | 06:40 PM
mozee82's Avatar
does this mean i have to take apart the steering wheel
Old Jul 29, 2010 | 10:07 AM
MSchu's Avatar
My Name is Nobody
your steering wheel lights up?
you need to remove the steering wheel and reassess the connectors to make sure that they are seated correctly... it doesn't sound like you assembly was reassembled correctly. even if the connector is seated, make sure your pins are all in good condition within the connector prior to reassembly.
whatever happened, there should be NO WAY that a wheel can spin 360 degrees... its a multi tooth cog and I really do not think you can get the nut on when the wheel is not seat appropriately.
Old Aug 3, 2010 | 06:14 AM
mozee82's Avatar
we never took the steering wheel off thats why i cant understand why it would be anything in the steering wheel itself
Old Aug 8, 2010 | 06:28 PM
soon2bdropped's Avatar
replace clock spring aka sprial cable. if your steering wheel did 360 than u snapped the clock spring.
Old Aug 12, 2010 | 06:05 PM
KWayRacing's Avatar
Absolutely. The cable reel assyembly twisted apart internally. You will need to remove the steering wheel to replace that. I suggest letting a professional handle that since it is safety related. The steering wheel was moving because the steering joint to rack connection was not poperly connected after the transmission install. Particularly the subframe install. That was a very dangerous mistake to make and should be noted as such. One has to always remember safety when working on vehicles. THis kind of error could have been fatal. NOt only for you but others on the road. So checking and rechecking what I call critical points is no waste of time. Steering joint connection is a critical point. Like ball joint nuts and cotter pins critical. The kind of stuff that makes body damage if you forget it. Anyway thats why I suggest finding someone more pro than the tranny team to tackle the cable reel assembly. Not saying you can't but there are special service precautions and procedures for installation. And also you'll most likely need the SRS light reset afterwards. Most serious import shops as well as the local dealer are able to take care of this easily.
Old Aug 15, 2010 | 01:42 PM
pw.hondatech's Avatar
yes,the clockspring/srs reel
^^ gökan^^
Suspension & Brakes
Jan 31, 2010 11:53 AM
hondahp21
Audio / Security / Video
Nov 18, 2006 08:09 AM
Finger Lickin' good
Mar 27, 2005 04:57 PM
aaaallll04
Jul 19, 2003 11:25 AM
