88 civic sedan motor torque problems and gear shifter moves.
I have had this problem where any time I get on it and let off the motor shifts. And my gear shifter or tranny shift any time I gas or let off. It is def bad when sitting on a heal and going in reverse. So far I have put brand new oem mounts on the driver passenger and rear.The front mount was replaced about a year ago. Just yesterday I put an energy suspension shifter stabilizer bushings. It still does this. I also have new prothane inserts for my passenger and driver side mounts. I am getting sick and tired of this shifting of my motor. Please anyone if you know what could be causing this. Thanks.
You should invest in the prothane front and rear mount inserts. I will worn you, you will have an increase in driveline vibration. You may not like it either. The shift you feel from the motor torque is normal. Some motors its more noticeable. You could also go with the replacement performance mounts with the harder inserts.
swizz977
21
Apr 14, 2012 07:13 AM
retrokidgeo23
Feb 20, 2011 05:07 PM
