Compression Test results - Help me diagnose
Old Jul 27, 2010 | 09:40 AM
Jimmy's Avatar
Global Moderator
Default Compression Test results - Help me diagnose
For starters me and my dad went in half on a 1991 honda civic hatchback, interior was in really great shape and we got it for 600 bucks. The original owner said one day the engine just died.
We towed the car home and the first thing I done was a compression test.
All four cylinders are 0. I dropped small amounts of oil in the cylinders, still 0.
My first guess is valves, but I'm really not sure as i've never went thru this process before.. I believe it's DPFI and the engine is a D15B1, I'll verify here shortly.
Any help from you guys is appreciated
Old Jul 27, 2010 | 10:10 AM
Scott_Tucker's Avatar
Default Re: Compression Test results - Help me diagnose
Is the timing belt broken?
Old Jul 27, 2010 | 12:17 PM
Jimmy's Avatar
Global Moderator
I'll pull the cover off and take a look..
Old Jul 27, 2010 | 12:21 PM
You can just remove the oil cap and have some crank it over and look into the hole with a flashlight and if the cam is not turning then the timing belt is broken.
Old Jul 27, 2010 | 12:30 PM
DDTECH's Avatar
Timing belt would be the first thing i look at.
Secondly would be the valves are probably gone..
Old Jul 27, 2010 | 12:31 PM
newtron63h's Avatar
timing belt or somehow all of the valves are way out of adjustment or bent or burnt or something of that nature. no unusual noises when cranking?
Old Jul 27, 2010 | 12:32 PM
newtron63h's Avatar
when cranking for the test does the needle move at all and then fall back to 0? or does it stay at 0?
Old Jul 27, 2010 | 12:41 PM
Jimmy's Avatar
Global Moderator
Just did this and the cam is indeed spinning.
Timing belt seems to be intact, if it's in time or not i do not know just yet.
Not really any unusual noises.. Seems like it's spinning a little bit fast
Just zero, didn't move at all.
I just posted so maybe I could get an idea if this engine is trashed or not, If i could slap a head on it that would be great, but if i haft to find another engine no big deal.. I've found one for 225 locally.
Old Jul 27, 2010 | 12:42 PM
AllMtrRex's Avatar
This, or is the cam broke. 2 years ago I bought a 1990 4 door civic with a broke cam right down the middle. Took a while to diagnose no spark because the last thing, I though of was is the cam even turning on the distributor/rotor side of the engine.
Old Jul 27, 2010 | 12:55 PM
newtron63h's Avatar
pull the VC off and see whats going on in there. check vlave lash, crank it with the VC off to watch vertything move. also pull off the radiator cap as you crank and see if there are any bubbles coming out there.
Old Jul 27, 2010 | 01:02 PM
Maybe your gauge is broken? Try it on one cylinder of another engine. If it works then you either have bent/burnt valves or holes in your pistons. I would lean towards valve but at any rate the head would need to come off for inspection. Its possible the timing belt is stripped but has enough to turn the cam and it has bent the valves.
Old Jul 27, 2010 | 01:03 PM
ZacCarter's Avatar
Jimmy I have a z6 and a hydro trans z6 trans. I also I have an a6 cable trans. I may have a a6 short block to I'll have to check at the shop. Text me if you need any of the parts or need help with the car. I'd be happy to come put my two sense into the car. LOL
Old Jul 27, 2010 | 01:04 PM
newtron63h's Avatar
checking the gauge is a good idea, also put ur hand over the oil cap hole while cranking before you pull the VC off to see if the rings are letting the compression leak.
Old Jul 27, 2010 | 01:05 PM
newtron63h's Avatar
sorry its off topic but where in TN are you guys?
Old Jul 27, 2010 | 01:13 PM
Jimmy's Avatar
Global Moderator
That was my first thought..As soon as I seen 0, ''This gauge is junk'' then i did all cylinders then I presumed to do a compression test on my jdm itr engine which yielded great numbers. So it can't be the gauge. Let's say it is in the head and the valves are f*cked, What are the chances it's hurt the pistons as well?
Hell yeah dude, Your more than welcome to stop by the house any time.. I guess you could say this is one of those father son projects..honestly i've never tore a honda engine completely down before, but i'm ready.. with the help of dad/friends
If you've got something we could put together for around the 200-250 range, i'm game.. I would love to get this car on the road very soon so I'm not having to daily drive my integra.
From my understanding it's going to take some wiring to swap in a d16z6..?
East Tennessee
Old Jul 27, 2010 | 01:17 PM
ZacCarter's Avatar
You gonna track this car or are you using this car to get the Rs off the road?
Newtron our location is the secretest of secret. I'll give you a hint though. If Lane Kiffin ever comes back to our town I'm pretty sure he'll be set on fire.
Old Jul 27, 2010 | 01:24 PM
Jimmy's Avatar
Global Moderator
I've gotta get my car off the road from DD. I only want to use my car for (2) things. Weekend Driving & Track, That's all i want from her.
I seriously feel very sorry for Lame Kiffin if he ever came back here. LOL!
Dude you've got to get over to my house sometime, MaD JDM ALL m0t0R grill outz over here y0!
Old Jul 27, 2010 | 01:30 PM
ZacCarter's Avatar
I'm home from work and don't have **** to do, don't have to be in tomorrow 'til 11. I don't sword fight though.
stan xx
Aug 28, 2015 04:29 PM
Wesleycrx
Dec 7, 2014 10:24 AM
mothornton
Dec 29, 2011 06:57 PM
RockLee`
Oct 29, 2006 03:43 PM
2k1 SSM GSR
Sep 13, 2004 12:18 PM
