gsr rebuild head is leaking a little in the front of the block do to tighten arp stud
It started leaking in the front of the block I need to figure this out before it becomes a serious problem motor only has one mile since rebuild also it is leaking from the oil pan to like 2 drips every minute so I think I need to retighten my arp head studs and change my oil pan gasket and everything will be ok.
1320vickers
Engine Machining & Assembly
Aug 3, 2018 12:30 PM
