372r with .90 a/r
Old Jul 27, 2010 | 07:37 AM
heavy duty's Avatar
Default 372r with .90 a/r
Has anyone done any test to see what the .90 a/r would make on a 84mm motor. If so please tell me psi and power.
Old Jul 27, 2010 | 08:06 AM
tony1's Avatar
Default Re: 372r with .90 a/r
Don't waste your time, if you're looking for low power than get a smaller compressor and turbine wheel. Choking a bit turbo up with a small housing will just get you bad results all around.
What is your power goal?
Old Jul 27, 2010 | 08:08 AM
pellis90's Avatar
Be more specific on set up, A lot will depend on head, cams, comp. ratio and fuel. What are you trying to do ?
Old Jul 27, 2010 | 10:09 AM
alpha's Avatar
Don't waste your time. But
https://honda-tech.com/forums/forced-induction-16/669whp-ls-dyno-2785064/
Old Jul 27, 2010 | 10:39 AM
N.Y.C.E.'s Avatar
27psi 760whp on a dyno-dynamics 840whp on a dyno jet on c16 no race cover, I still run this turbo and it works great!
Old Jul 27, 2010 | 11:24 AM
heavy duty's Avatar
So you are running a .90 a/r.
O and 4 a very little time i will have it on piston and rod stock sleeve motor. I had a 4294r on it and it was hurt. Now i would like to do this with the .90 a/r. It is also a stock port head. It has a old set of crower turbo cams. I know it will not be that good for a 84mm motor but maybe a 81.5 and 9.5.1 cr motor. Only looking for about 650 right now but when i get the new motor done i will need the big turbo and i will get a 1.25 a/r.
Old Jul 27, 2010 | 11:48 AM
N.Y.C.E.'s Avatar
Yes .90 a/r through full 4inch exhaust, honestly with your new build that turbo is more than enough you have guys out there with smaller turbos making big power, exhaust cam is very important!
Old Jul 27, 2010 | 12:08 PM
PHDZINE's Avatar
I put down 845WHP on a .90 A/R with regular cover
Old Jul 27, 2010 | 12:34 PM
heavy duty's Avatar
Can you and nyce give me some info on your motors.What psi was that at.
Old Jul 27, 2010 | 02:15 PM
N.Y.C.E.'s Avatar
Skunk2 Pro 1 cams ,
ported B16 head,
84mm Arias flat top off the shelf pistons,
Pauter Rods,
90mm tb
27psi
Old Jul 27, 2010 | 02:30 PM
PHDZINE's Avatar
84mm B18C
CP shelf pistons
Golden eagle block
Pauter ported GSR head w/ 2mm oversize valves
WebCams
90mm Q45 Throttlebody
@38 psi
...pretty basic set up.
We also ran the bigger A/R housing and made more.
Old Jul 27, 2010 | 02:43 PM
PHDZINE's Avatar
...here is the dynograph with the .90 A/R turbine housing and standard comp. housing @ 38psi
Old Jul 27, 2010 | 03:03 PM
Garage 808 Hatch's Avatar
600whp @ 24psi
Old Jul 28, 2010 | 03:44 AM
heavy duty's Avatar
Was the turbo taped out or not. Was just thinking were it will stop.
Old Jul 28, 2010 | 11:32 AM
PHDZINE's Avatar
IDK...we stopped dynoing after that and tuned the rest on the track up to 48 psi and it needed alot more fuel, so im assuming it wasnt taped out.
Old Jul 28, 2010 | 07:55 PM
speeddave's Avatar
When do you reach full boost with the .90a/r and is there that much difference between that and the bigger housings in spool/response to warrant limiting power output?
Old Jul 29, 2010 | 03:59 AM
heavy duty's Avatar
This is what i was jusk going to ask.
Old Jul 30, 2010 | 08:56 AM
PHDZINE's Avatar
Full boost with the .90 is roughly 6500rpm and 1.15 it was 7000rpm and the 1.25 was about 7500rpm but it really doesnt matter for what we are doing. You have the boost builder/two step etc. to build boost when you launch. but remember, if you aren't spinning enough rpms when you shift, you will probably fall out of boost when you shift.
Old Jul 30, 2010 | 11:46 AM
heavy duty's Avatar
How much power do you think the 1.25 helped.
Old Jul 30, 2010 | 12:31 PM
going from the .90 to the 1.10 it only changed spool up by 100rpm. but made the same power with 3psi less boost. In my case anyways
young geezer
Jul 28, 2014 12:04 PM
x275radial
Feb 17, 2013 08:56 AM
crxdonwon
Nov 27, 2007 09:18 PM
Huee
Nov 30, 2004 09:34 AM
