supercharger or turbo?
Old Jul 26, 2010 | 02:29 PM
albyvx's Avatar
Default supercharger or turbo?
eh howsit im new to this forum but i have a 92 civic hb with a gsr motor in it with all the bolt ons but i was looking into a lot more POWER! i wanna get above 300hp im debating whether to go with a jackson racing supercharger or a turbo kit... all comments welcome and if you have a link to a kit i could possibly use id appriciate it
mahalo!
Old Jul 26, 2010 | 03:33 PM
TunerN00b's Avatar
Default Re: supercharger or turbo?
If you want 300+ whp, then a supercharger won't cut it.
This question has been asked countless times before. Head over to the forced induction forum and read up.
But this thread really doesn't belong here in the Integra forum...
Old Jul 26, 2010 | 08:37 PM
jdm_bones's Avatar
NA k24 bottom with high compression pistons on a K20R head with Skunk2 stage2 PRO cams, 440 injectors, Skunk2 mani and TB and KPRO tune...Forget the snail, and the belt....N/A is my vote.
Old Jul 26, 2010 | 08:53 PM
Spawne32's Avatar
supercharger is obviously the cooler way to go.
Old Jul 27, 2010 | 11:24 AM
bman5000's Avatar
dude my boy has a jackson on a fully built GSR and man is that car fast it smassssshes my turbo LS for days @12psi with the supercharger the power is right there when u lay into it unlike a turbo wen u have to wait for it to build boost< i mean turbos can def make more power its kinda just yer prefrence<
Old Jul 27, 2010 | 11:26 AM
Spawne32's Avatar
thank you for that in depth analysis
Old Jul 27, 2010 | 02:15 PM
hbcrazy88's Avatar
use a turbo, the k24 would be more expensive then 3k. use a peakboost kit and you will get well over 300whp
Old Jul 27, 2010 | 02:16 PM
singlecamslamed's Avatar
Stage 3 CLINGER!
I use an electric turbo.
Old Jul 27, 2010 | 03:14 PM
dc101's Avatar
let the domestic guys have their superchargers
Old Jul 27, 2010 | 03:16 PM
wtf_is_jdm's Avatar
200 shot of nos. your good to go.
Old Jul 27, 2010 | 05:50 PM
Jaymoney$'s Avatar
really?
Old Jul 27, 2010 | 06:55 PM
boostedeg302's Avatar
Cmon man. 300whp with a supercharger is about all your gonna see. The limits of turbocharging are endless. Screw all motor and spray, turbo is the way to go. Do a search next time before posting, this question has been asked countless times. As for the k series build, if you wanna spend thousands of dollars and get smoked by a stock boosted gsr, go for it
Old Jul 27, 2010 | 06:56 PM
Spawne32's Avatar
The limits of turbocharging are not endless if you want to run on pump gas, most turbo charged applications will hit a wall at 400hp unless they are running some kind of enhanced octane you cant get at the pump.
Old Jul 27, 2010 | 07:23 PM
dev203d's Avatar
Basically here it goes
Supercharger: PROS: Great power throughout all RPM's from low to high
CONS: Heavy in weight and can't get Max power like turbo's.
Turbocharger: PROS: Light weight, unlimited power potential (based on turbo size)
CONS: Turbo Lag (Takes time for turbo to spool up and make power)-So no low end power.
Old Jul 28, 2010 | 04:37 AM
vladd's Avatar
300 whp on a supercharged gsr? i'd love to see that. doesn't the jackson racing s/c give you like 225 whp? that's with the usual i/h/e and tune.
Old Jul 28, 2010 | 09:12 AM
Spawne32's Avatar
300whp on a supercharger is easy if you have the right mods, im trying to push for that on the MP45 supercharger as well
Old Jul 28, 2010 | 09:29 AM
kouvang706's Avatar
Turbo is the best bang for your buck. Depending on your budget and how much hp you want from your build. My two cents..
Old Jul 28, 2010 | 11:16 AM
TunerN00b's Avatar
People who think a turbo can't make low end power have obviously never experienced a turbocharger sized properly for it's intended use.
My turbocharged car makes peak boost (and peak torque) at 1,850 RPM, and carries the torque flat to 4,500. It actually lacks high RPM power. Perfect powerband for a daily driver, but not nearly as fun on track as my rev happy GSR...
Old Jul 28, 2010 | 11:59 AM
mac_24_seven's Avatar
I'm sure it's a very small turbo.. Probably stop pulling around 7k?
My turbo is at full boost around 4k. It doesn't take very long to get there either.
Old Jul 28, 2010 | 12:00 PM
20-EM2-05's Avatar
Just twin charge it.
/thread
Old Jul 28, 2010 | 01:22 PM
TunerN00b's Avatar
K03, and it stops pulling around 6.5k. But it's fine since the engine, the automatic, and the wife, all prefer to not rev higher than that anyway.
Old Jul 28, 2010 | 11:16 PM
albyvx's Avatar
mahalos for all the posts! i just came to this from clubeg6 which ive been on for a while and havent really been getting any good feed back. one of my best friends has a hatch with a fullllyyyy built dart motor and a rev hard kit making 500 hp to the wheels and hes giving me different options cuz i wanna make high hp without the headaches! mahalos again good or bad!!! if you guys have links to any good turbo kits please lemme know
aloha
Old Jul 29, 2010 | 07:27 AM
boosted_teg10's Avatar
to start i am just gettin in the turbo game but my car was SC for 4 years and i am already likein my turbo better i was pushin 9 lbs on my jackson and only put down 232 hp and i am only on 6 lbs on my turbo build and 310 hp. My SC setup was a b20 bottom end with crower rod mahle pistons 10.0.1 gsr head with ferra pro comp valves crower spring and rettianers gsr cams witch are recominded by skunk2 kamakize header and 3in exhaust the only way i got that set up while SC was to put the spray to it i put a 30 shot on it and the blower loved it made 300 hp and 278 t my turbo build is a peakboost kit same motor ex its sleeved with 10.5.1 and skunk2 pro 1 cams and am puttin dwn 310 and 238 so there is power to be made with the SC but the high Intake temps are not worth it to me
Last edited by boosted_teg10; Jul 29, 2010 at 07:28 AM. Reason: type somethin wrong
Old Jul 29, 2010 | 09:44 PM
vladd's Avatar
tell me more. i haven't been keeping myself updated on integra info lately.
Old Jul 30, 2010 | 11:46 AM
jdm95's Avatar
Well sorry to say but your wall theory is not correct and even if it were a supercharged application would never see 400 HP anyway.
Its really all about intended use... are you doing SCCA autocross events were you want the power through out the whole powerband or are you looking to put down some serious numbers. These are the questions the OP should be asking himself.
turbo= big horse power
Supercharger= a good boost in power through out RPM's but wont be winning any drag races. Still fun for a daily driver.
gotvtc
Sep 26, 2008 11:56 AM
waijsR
Aug 20, 2004 12:19 AM
Chas
Nov 4, 2003 05:24 PM
thaigsrdrv16
Jan 13, 2003 09:14 AM
B19CivicHB
Oct 27, 2001 05:59 PM
