2000 si comp test results
The Haynes manual says the standard B16A2 should have 184 psi compression and the minimum is 135. The maximum allowable variation between cylinders is 28 psi per Haynes. The factory shop manual doesn't list a pressure but matches Haynes concerning the 135 minimum and 28 pound variation.
it has 155000 miles on it has a short ram aem intake but other than that its stock.the thing is i forgot to hold the throttle open while i checked it
hondacrx2
Sep 1, 2010 02:33 PM
Si_chRis
15
May 26, 2006 08:46 AM
