Should be easy for you guys? A/C Question?
My a/c used to work great! I got in a front-end collision. This smashed my condenser. I replaced my condenser and it worked again for a couple days, then had to replace my compressor. Ever since, it's been working... just not well. It never gets COLD. At night, in the rain, or any time it's not warm outside, it appears to cool very well. But during the day, you can hardly tell it's cooler than outside temperature. I checked the pressures and everything checks out to be fine. (High and Low) Everything is filled up to where it should be and there are no signs of leaks.
I took it to an A/C shop so I can get my COLD back. All he said was that since I replaced it with a NEW condenser from Autozone, that's my problem. He said it had to be a Honda Factory condenser to get cold and work again. Is this true? Or what else should I do? Anyone have a similar problem? Thank you. My 2 year old and me would APPRECIATE it!!
I don't remember the specific readings, but a mechanic said they were very normal. I remember they were both in the blue. The condenser fan comes on as it should. As far as the brand of condenser, not sure about that. It's a 99 civic EX. Thanks!
I haven't tried that, but like I said, when it rains it gets as cool as it gets. So if I sprayed water on the condenser on a hit day and it DID get cold, what dies that mean? I know my fans come on.
The condensor is what turns the freon gas into a liquid to absord the hot air from the cabin.
If by throwing cool water on the condensor the A/C blows colder, means that the fan isn't doing it's job or the gas is sooooo hot that the condensor fan cannot do an efficient job turning the gas into a liquid. The condensor is considered the high side and the compressor is low side. This doesn't rule out the fact that you compressor may not be doing an efficient job compressing the gas or it could be pushing the gas through so fast it's not cooling it properly.
Could be a clogged condensor, clogged evaporator (this is under the dash I think) or bad compressor. I would buy an OEM Honda compressor and see if that's the issue.
Also, if you could get the actual pressure readings from the A/C man, it can help you figure out what's going on b/c for any pressure there is a pretty specific temperature corealtion (sp?) and for cars, if the outside temp is 85*F and the temp of the air coming off the condensor is 115*F, the high side pressure should be 243psig.
I think it's the compressor, this is really the only variable to the equation, considering the A/C was cold prior to the accident.
Greyout
19
Jun 18, 2014 12:41 AM
bokeyboone
Oct 7, 2008 11:10 PM
