Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Stuck rear caliper pistons - any help?
Old Jul 22, 2010 | 12:50 PM
xxpaulcpxx's Avatar
Default Stuck rear caliper pistons - any help?
My 07 EX has about 30K on it, and I'm replacing all the brakes.
Front went fine (except when I bent a caliper pin), but I cannot get the rear caliper pistons to compress so that I can get the new pads on. I
I've tried a regular caliper tool and nearly stripped it out, I even buckled down with big C clamps to no avail.
The parking brake is off, and I even released the tension on the brake cable.
What else can I do?
Last edited by xxpaulcpxx; Jul 22, 2010 at 12:51 PM. Reason: to get email notification
Old Jul 22, 2010 | 12:59 PM
dpetro1's Avatar
Default Re: Stuck rear caliper pistons - any help?
you need to buy or rent the proper tool. most rear honda calipers have the parking brake integrated into the caliper so you have to screw the piston in (you cannot just compress them with a c-clamp).
http://www.harborfreight.com/18-piec...kit-97143.html
Old Jul 22, 2010 | 01:03 PM
xxpaulcpxx's Avatar
Ahhh, I wondered how they self adjusted. Thanks for that!
Old Jul 22, 2010 | 01:04 PM
na+b18c_hatch's Avatar
OP: you should be able to get a tool, most commonly referred to as a caliper cube, at sears or your local hardware store. Its shaped like a cube and has an adapter for a 3/8" ratchet. This tool will allow you to press and rotate the piston simultaneosly for effective and successful rear brake pad replacement
EDIT: see picture.. just an alternative to that whole kit posted above ^^
Old Jul 22, 2010 | 04:34 PM
i-VTEC_DOHC's Avatar
just get a big flathead screwdriver and twist the caliper to the right. it threads back in and thats it. thats what i did on mine. took me 10 minutes to do both sides.
Old Jul 23, 2010 | 09:57 AM
xxpaulcpxx's Avatar
Thanks for those tips. I had subscribed to the Helm site for the online manual, and nowhere did I see anything about "screwing in" the rear caliper piston.
I suppose that's to be expected... if you want to drop your oil pan in a CRX, it requires referencing 4 or 5 different sections of the FSM!
Old Jul 24, 2010 | 03:34 AM
97civicdx's Avatar
I picked up a brake caliper tool kit from Harbor freight Tools that has this piston adjusting adapter for like 20 bucks...............
Old Jul 25, 2010 | 07:22 PM
lazlong's Avatar
You shouldn't have to exert enough force to bend that pin. Are you opening the bleed screw, compressing the piston, then quickly closing the bleed screw?
Also, if you don't lube those pins your caliper will bind when the piston pushes the pad. Causing less braking power, grinding noises, possible warped rotor, possible caliper failure, and this: http://www.civicforums.com/forums/18...ew-brakes.html
Old Jul 25, 2010 | 11:01 PM
xxpaulcpxx's Avatar
I had a big C clamp on the caliper holding it down while I compressed the opposite caliper - this way the brake fluid doesn't push out the other caliper, it just feeds back to the reservoir.
However, when i turned the wheel to get to the bolts on the other caliper, I pushed the clamp into the wheel well, which bent the soft upper caliper pin.
And yes, I did re-lube it before I put the new one in.
Old Jul 25, 2010 | 11:12 PM
pd0019's Avatar
you do not need to worry about brake fluid shooting out of the reservoir if you compress the piston at slow enough rate.
i would never open the bleed screw as lazlong said unless i placed a hose over the screw. if you just open the screw without placing a hose over it there is a possibility of air getting into the line and obviously air in your brake line is not good. putting a hose over the screw allows you to release the pressure while at the same time preventing air from getting into your line.
when doing the rears, you should get the special tool. you can use the cube one as pointed out above, but there are other tools that can be used.
Kevin Nealis
Apr 19, 2015 07:53 PM
leviq
Jul 7, 2007 08:28 AM
boost4life
Honda S2000
Jun 2, 2007 11:41 AM
EJ8 Kenobi
Jun 16, 2003 06:32 PM
HondaJon
20
May 30, 2003 07:42 PM
