92 civic overheating problem
Hello, I have a 92 civic lx that has an overheating problem. It only seems to happen after driving on the highway for a while. After driving about 30 minutes I got off the highway and the temp gauge climbed pretty fast to hot. As soon as I started driving again it went down almost to normal. Next stop it climbed again. Also while stopped if I put the heat on high it drops a little. While stopped I opened the hood and the fan was on. Other thing I noticed was the reservoir was full to the top. After it cooled down the reservoir was almost empty and the radiator was full. I let the car run for about an hour in the driveway and it was fine, no overheating. Did a little highway driving and the same thing happened, temp gauge shot up and reservoir full again. Any ideas? thanks
start with the simple stuff first. check your coolant level, check for any obvious leaks, then make sure your radiator fan is working. when you stop at a traffic light the rad fan moves air across the radiator cooling the car. without the fan on the car will overheat very quickly.
radfanjam
Honda Civic (2001 - 2005)
Jun 24, 2016 07:14 PM
pigskinrodeo
May 15, 2013 10:19 PM
