HELP!!! my del sol wont move!!!
so as title states, my 93 del sol will not move under its own power, although the transmission does go through the entire h pattern and feels/sounds just fine. the clutch engages and disengages just as it should, but when the clutch is fully released and in gear, any gear, it feels like something is grinding on the inside of the driveline, i can feel it through the selector rod of the tranni. i just replaced the transmission myself, as i graduated wyotech not even 2 months ago, but the clutch plates looked good and everything meshed in and bolted up without any problems. i looked for a broken cv axle and found nothing, as well as looking for any suspension or steering components but yet again to find nothing. however, i did have a tire tread kicked up at me on the freeway, and it completely swiped out the front end of my car, my fiberglass bumper was torn into two! iv got it basically back together now, but later that night(yesterday) i was taking off from a stop sign and the car just laid flat on its face and rolled to a stop so im forced to leave on the side of the road, at least in between two houses,any ideas guys????
but woulden't the other axle still be connected and cause it to still drive but with a bunch'a noise and a excessive amount of pull if that were the case and im starting to think it might the output shaft gear that connects the clutch to the transmission
hatchet37
37
Dec 17, 2014 04:52 PM
