How much boost?
Old Sep 15, 2002 | 09:13 PM
GZERO's Avatar
Default How much boost?
Hey people, this is my first post. I have a F22B2 with a turbo kit from F-max and arias pistons and crower rods, and i wanted to know how much boost i can run with this setup and what could be the best presure to run at normal driving, i do a lot of driving in this car, and i would like it to last, and sometimes switch the boost and make it go, i was thinking running like 6 psi on normal and around 12 or one bar of boost sometimes, what do you guys think? and what do you guys are running? i'm interested in opinions and ideas from anyone.
Old Sep 15, 2002 | 09:27 PM
Brandon's Avatar
Life is Suffering
Default Re: How much boost? (GZERO)
1 Bar sounds like cake for that motor. You shouldn't have any problems with it.
Old Sep 15, 2002 | 09:29 PM
FastechAccord's Avatar
your setup with pistons, rods and stock sleeves will allow you to run alot of boost. The sleeves are quite strong, so the only thing you really need to worry about is fuel setup. Other than that, you should be perfectly fine.
Old Sep 16, 2002 | 02:05 AM
niedejb's Avatar
I run 10 psi daily and 13 psi with a press of a button.
Old Sep 16, 2002 | 06:19 AM
rrei's Avatar
Default Re: How much boost? (niedejb)
so you dont need to resleeve the accord motor, just rods and pistons will do for ow much psi is that safe.
Old Sep 16, 2002 | 07:52 AM
Nick H's Avatar
New User
overboost owns jo0
Old Sep 16, 2002 | 08:14 AM
Nick M's Avatar
Default Re: How much boost? (nickh2k1)
Dont accords have the same material thats also used in H22a sleeves? FRM or whatever its called? So the use of forged pistons will require resleeving. Right?
Old Sep 16, 2002 | 08:36 AM
Accord94DX's Avatar
Default Re: How much boost? (HondaSport)
no. accords do not have FRM in the sleeves.
Old Sep 16, 2002 | 12:40 PM
niedejb's Avatar
overboost owns jo0
No overboost. It goes to 10 or 13 rock solid. No spiking what so ever.
Or are you saying this is too much boost altogether?
Old Sep 16, 2002 | 12:42 PM
Brandon's Avatar
Life is Suffering
If so, I question is turbo savvyness.
Dave_Dc2
Apr 21, 2009 03:29 AM
bboysake
Aug 11, 2006 03:02 PM
Del$olB16A3
Mar 27, 2005 07:23 AM
Nikoli
May 30, 2004 07:31 AM
808b18c1boosted
Dec 19, 2003 04:08 PM
