Transmission & Drivetrain Gearboxes, Differentials, Clutches
k20a2 tranny problem....help
Old Jul 20, 2010 | 05:38 PM
jdm_obsession88's Avatar
Default k20a2 tranny problem....help
I bought an ej6 with a k20a2 swap last week. the guy said he had trouble getting it into 6th gear most of the time but after looking over it the past few days. From what i have noticed, when im sitting still w the car started or not, it goes into every gear very easily, but while driving it wont go into 6th at all. No grinds just wont go in, also 5 gear seams to be way further to the right and is notchy while driving than when at idle, as wierd as that sounds. Any help is appreciated. thanks
Old Jul 21, 2010 | 01:01 PM
Default Re: k20a2 tranny problem....help
Do i just need a new clutch or what...any help?
Old Jul 23, 2010 | 01:59 PM
73 views and no help...I know its prob. a noob question but i could still use the help. Thanks
Old Jul 23, 2010 | 10:07 PM
unusual71's Avatar
it could be the shift change mechanism thing. how are the shifter cables?
this isn't a clutch problem.
I have only fixed 1 k-series trans so im not too familiar but its likely shifter related the internals are pretty good.
also check for the condition of the shifter box inside the car
Old Jul 24, 2010 | 01:51 AM
chewyv's Avatar
pm4nudes
Im sure there was an thread about the k series transmission engagment being different on k20a.org. But anywho if 5th is notchy and a little out of place than I would assume that 6th is also out of place so your just gonna have to put a little pressure on it, play with it and try to find it.
Old Jul 24, 2010 | 12:49 PM
Shifter cables look perfect. shifter box looks good to inside the car. but the guy says it got like that over time. he used to be able to get into 6 gear.
Old Jul 24, 2010 | 12:51 PM
all the gears are there and in place when sitting still but when i start moving..no 6 gear and 5th moves over.
vosoka
Dec 13, 2009 12:39 PM
blue89hatch
Nov 19, 2008 09:00 AM
snzh22
Aug 19, 2007 09:51 AM
crazivi3tdude
May 11, 2005 11:28 AM
Nevaeh
Sep 30, 2004 03:18 PM
