5th gen tranny vs. 6th. Same gear ratio? If not, which is better?
Old Jul 20, 2010 | 11:38 AM
EJeff8's Avatar
Default 5th gen tranny vs. 6th. Same gear ratio? If not, which is better?
So, we've all seen my terrible thread and how I learned my bearing is bad. I'm picking up a 1992 tranny with 92xxx miles supposedly this Friday. I know all D trannys are essentially the same but are the gear ratios different? what do I lose or gain moving to a 5th gen?
I have a 2000 Ex Y8 5spd.
Old Jul 20, 2010 | 12:16 PM
EJeff8's Avatar
Default Re: 5th gen tranny vs. 6th. Same gear ratio? If not, which is better?
Also, I plan on replacing the clutch kit. I'd buy for a '92 tranny right? And I'm N/A and plan to stay N/A so just stay OEM?
Old Jul 20, 2010 | 01:44 PM
kzelisko's Avatar
Clutches for d-series hydro transmissions are all the same. As for the gearing, it depends on what car and engine it came from. Cars with the y8 and the z6 have more or less the same gearing, though del sol si's and civic si's have the shorter 5th. Everything thing else has different gearing. 5th gen transmissions that are not from the z6 also have smaller bearings in various places throughout the transmission.
Old Jul 20, 2010 | 01:51 PM
EJeff8's Avatar
^It's coming from a '92 Z6 (pretty sure) into an '00 Y8. So I won't see any noticable changes to me?
I'm assuming it's an ex tranny too but he has yet to clarify. Is it that bad if it's a dx 5spd? I've heard they aren't built as well and would have different ratios.
Old Jul 20, 2010 | 03:24 PM
D Griff's Avatar
If it's from a Z6 it should be nearly the same. If it's from a DX or other D15B equipped car, the gears will be a little taller, you'll maybe get a tiny bit better fuel economy and it'll feel a wee bit slower. They'll all work fine though, really.
Old Jul 20, 2010 | 04:19 PM
EJeff8's Avatar
^ haha, well it's a Z6 tranny, he confirmed. So getting this tranny, a new OEM clutch kit from Exedy and an OEM throw out bearing with two quarts of HMTF, my swap is looking at about $320. Not too shabby =]
Old Jul 20, 2010 | 07:17 PM
EJeff8's Avatar
Now, obviously it will match mechanically but will it match electronically? It's a 5spd so there's no planetary gears and computer crap to worry about. Just a few sensors that'll pop right in correct? Brake light, VSS and such?
Old Jul 21, 2010 | 11:37 AM
EJeff8's Avatar
Bump?
Old Jul 21, 2010 | 01:31 PM
94EG8's Avatar
Seagull Management
Backup light switch is identical, VSS is physically different, but the plug is the same and it works the same, basically you just can't use an OBD2 VSS in an OBD1 tranny and vice versa because of a mounting issue. OBD2 VSS's are 1 piece all plastic, OBD1 are 2 piece plastic and metal.
Old Jul 21, 2010 | 04:30 PM
EJeff8's Avatar
Damnit! If I rigged it to stay for an amount of time until I got the VSS, would it work though? Cause I have to fix this and then take it on a trip.
Old Jul 21, 2010 | 04:39 PM
EJeff8's Avatar
Actually it's not bad if auto and manu VSS's are the same because I can just pick one up at the graveyard I live by for cheap. They don't have any manuals, so an auto would have to work.
Old Jul 21, 2010 | 04:48 PM
94EG8's Avatar
Seagull Management
Normally when you buy a used transmission they still have the VSS attached. I've never tried using an OBD2 VSS in an OBD1 tranny to check fitment. I'm almost postive the wont just interchange though.
Old Jul 21, 2010 | 06:30 PM
EJeff8's Avatar
Yeah, I don't see why they wouldn't just unclip the VSS instead of unbolting it. But would an auto OBD1 VSS work just the same if it's worst case scenario?
Old Jul 22, 2010 | 01:51 PM
94EG8's Avatar
Seagull Management
Nope, automatic OBD1 VSS wont even work in an OBD1 5 speed tranny. (the electronic top half is the same, but the bottom half is different)
Old Jul 22, 2010 | 04:33 PM
EJeff8's Avatar
Well, I confirmed it's in it so WCS avoided
Tom123456
Jul 28, 2006 12:32 AM
tobe1424
62
Mar 7, 2006 07:16 PM
christhereefer
13
Oct 3, 2004 12:23 AM
egizzle8
14
Sep 28, 2003 09:52 AM
spencedogg
Aug 10, 2003 05:59 AM
